Scott CR1 Carbon strip question
PhilWalterNZ
by PhilWalterNZ
I have stripped back my scott cr1 saunier duval to raw carbon ( using the craft knife method), and plan to leave it that way. Around the joins ( headtube, BB and around the seatpost there are some thin strips of red in the areas where the tubes are bonded. My quesion is, can I scrape that away also or would that compromise the strength of the frame ?
I'm happy to leave them there, as it adds to the raw look, but if you can scrape it off, then I would probably do so.
Thanks !
...i scraped out the filler they use to smoothen out the joins, but the red stuff looks a bit more serious and is a lot harder.
weeracerweenie
by weeracerweenie
My addict was the same. The red is the residual glue. It's not structural if its sitting on the outside of the carbon. Scrape her off.
I guess there's worse hobbies than making a bike light? Right?
