It is currently Fri Jan 19, 2018 9:04 pm
PostPosted: Wed Sep 11, 2013 9:38 pm
Hey folks! I need some WW advice!
My pressfit bottom bracket has been squeaking like hell lately so finally got round to replacing them.
I used a parktool BBT-90.3 when removing the BB cups. After 30mins of hammering none of the cups seem to budge. Eventually the bearings popped out but the actual cup (casing?) is still in the frame! I proceeded with the other side and same thing.
So now how on earth can I get the casings out!? I cant seem to find anyone on google with a similar experience! The parktool seems worthless now for the purpose.
HELP! And please dont tell me a drill is the only option out :oops:
Sunny cycling holidays in Portugal @ Cherry Cottage Vintage B&B
PostPosted: Thu Sep 12, 2013 1:36 am
One of these: http://www.parktool.com/product/head-cup-remover-rt-1
PostPosted: Thu Sep 12, 2013 2:16 am
press fit in, push out
PostPosted: Thu Sep 12, 2013 7:29 am
^ Already have one of those. Point was that the bearings came out which is where the tool applies its pressure but the rest (cups) stayed in.
Finally managed to release them though. How so?
1) Added some additional pressure on the parktool lips by spreading them out as much as possible.
2) Wedged them between the grooves of the cups. This aint easy as the cups have that inner cilinder thats pretty flushed with the cups.
3) Bang Bang and out they came
Its a pretty violent process. Hammering your bike to death does not come natural! :mrgreen: Ok all good! Thanks!
PostPosted: Thu Sep 12, 2013 8:50 am
I've had similar experience, but once I supported the BB shell appropriately and got over the fear of hammering the F%#k out of the frame, they came out easily...
PostPosted: Thu Sep 12, 2013 1:55 pm
Had the same issue removing Cannondale's alloy PF30 bearing cups that were installed with Loctite retaining fluid and pretty much did the same thing to the Park tool which really mangles the back side of the cups. Until Park, Pedro's or other tool company makes a better tool, seems like PF30 bearing cups are not likely to be reused.
PostPosted: Thu Sep 12, 2013 2:15 pm
You said you had Park 90.3 - that removes the bearings. A Park RT1 or similar 1 1/8" head cup remover is for removal of the cups - the inside diameter of a PF30 bottom bracket is the same/similar to a head tube that takes an 1 1/8" steerer.
PostPosted: Thu Sep 12, 2013 3:06 pm
Sorry I hadnt realized they were different. That would have sorted me out! I'll keep this in mind next time if It happens again. Cheers :beerchug:
PostPosted: Thu Sep 12, 2013 3:17 pm
wooden dowel?
PostPosted: Fri Sep 13, 2013 12:38 am
What sort of PF BB was it? PF30 or shimano press fit? Did you have Al or plastic cups?
Plastic cups make less noise. When you have bearings straight onto the crank axle like BB30, or straight into an Al cup you have far more chance of creaking.
Seems to be a big problem on BB30/PF30 where the bearing sits right on the axle. Is caused by a small tolerance mismatch between the inner race and the axle OD allowing a small amount of movement, and then that noise is amplified in the frame.
Fix it with some mild loctite
There are no new unread posts for this topic. Damaged surface of Campagnolo Ultra Torque PressFit Cups
3Pio
32
2064
Sun Oct 15, 2017 5:44 pm
winkybiker View the latest post
There are no new unread posts for this topic. Vumaquad on a pressfit bbright
JLS
Sat Feb 04, 2017 8:27 pm
BMWCARMAN View the latest post
There are no new unread posts for this topic. Tune Schwarzes Stuck, any experience?
Penthousepete
Wed Oct 11, 2017 2:32 pm
Penthousepete View the latest post
There are no new unread posts for this topic. Campagnolo SR ITA BB cups installation method
karhu
14
856
Mon Jul 03, 2017 11:15 pm
AJS914 View the latest post
There are no new unread posts for this topic. Campagnolo UT SR BB Cups - difference between 2011 and 2015 versions?
RJKflyer
Tue Apr 11, 2017 9:49 pm
Calnago View the latest post
Users browsing this forum: Baidu [Spider], dim, duende, hidefguy, JoO, jpshorts, wobbly and 62 guests
