It is currently Fri Jan 19, 2018 12:56 pm
Post new topic  Reply to topic  [ 17 posts ]  Go to page 1 2 Next
PostPosted: Wed Sep 11, 2013 12:04 pm
I've tried searching your forums but can't seem to find any concrete evidence if....
.... a Shimano 9000 crank will work with a 10 sp Di2 set up?
I've read posts where some have, but it's not clear if a 10 sp or 11 sp chain is used and whether front shifting is in any way compromised as a result...?
Shimano say it doesn't work but they sure would say that...
Thanks
PostPosted: Wed Sep 11, 2013 12:50 pm
It's in here.
But can confirm, yes it works fine. I have my 9000 SRM on my 10sp Di2 bike - no worries.
VeloKicks
The Gram
The Men of Steel
PostPosted: Wed Sep 11, 2013 1:12 pm
Yes, my mate is currently running a DA9000 crankset with a 10 speed 105 groupset (filthy, I know. He has been instructed to upgrade to full DA9000 ASAP).
Works totally fine.
PostPosted: Wed Sep 11, 2013 6:59 pm
3rd to confirm yes will work.
Madone Five Series 2013
Shimano Dura-Ace 9000
Mavic Cosmic SLE 2013
PostPosted: Wed Sep 11, 2013 8:53 pm
Yes, and you can use the 11-speed chain if you want.
my plastic bikes, 29ers & stable of old steel
PostPosted: Wed Sep 11, 2013 10:53 pm
Works fine. 11 speed or 10 speed chain, no issues.
PostPosted: Wed Sep 11, 2013 11:32 pm
So will the 11 speed chain work fine on the 10 speed cassette and chainset?
PostPosted: Thu Sep 12, 2013 7:29 am
Thanks all for confirming.
Meanwhile I get this comment from Shimano:
{USERNAME} wrote:
...because the chains have other dimensions, the function is not optimized. Our groupsets are system engineered which means optimized to work with each other as one. Since there are differences between 10 and 11 speed parts we do not advice to mix parts.
PostPosted: Thu Sep 12, 2013 11:57 am
The 11 speed chain is the same inner width as the 10 speed chain.
The outside width is narrower;
Meaning you can use the 11 speed chain on 10 speed equipment, but not a 10 speed chain, on 11 speed equipment.
If that makes sense!
PostPosted: Thu Sep 12, 2013 1:48 pm
hatone wrote:
Which translated into non-marketing hype means we don't recommend it because we don't make as much money. I am running DA 9000 front derailleur and chain with FSA K-Force SRM, DA 7900 shifters, rear derailleur, and Ultegra 6700 cassette with no issues on the wife and my TCR Advanceds.
PostPosted: Fri Sep 13, 2013 9:46 am
Very useful info there, thanks. So you're saying if you have a 11 sp crank, using a 10 sp cassette & derailleur you still need to use a 11 sp chain, correct?
PostPosted: Fri Sep 13, 2013 11:09 am
As long as the rear end is 10 speed *either* 10 or 11 speed chain will work. If you'd gone 11 speed back and 10 speed front, only an 11 speed would work. Its the rear cluster that is the important one. FWIW, lots of people run 10 speed chains on 9 speed MTB set ups.
They've been saying similar since we took the leap from 6 to 7 speed drivelines, it was (mostly) rubbish then. Most of the kit works together. Just not at 100%, sometimes the difference isn't even noticeable (and sometimes, mix n match works better!)
PostPosted: Fri Sep 13, 2013 11:21 am
I run a 7900 SRM on my 9000 race bike.
Again, it's fine. In fact, most Pro's were doing it this year.
VeloKicks
The Gram
The Men of Steel
PostPosted: Sat Sep 14, 2013 8:51 am
No, if you have an 11sp crank, and a 10 speed cassette and rear mech, you can use either.
It is only the presence of an 11 speed cassette that forces you to use an 11 speed chain.
However, my very trusted friend and ultra-mega-bike-tech researcher and parts spreadsheet creating cyber-nerd mechanic at my LBS who has been trained at the Shimano HQ in Osaka tells me that running a 10 speed chain on an 11 speed cassette works fine. He also added that as the 10 speed chain stretches, the system doesn't function exactly perfectly, but still for most people they will not notice and it will be fine.
Haha, exactly.
PostPosted: Tue Sep 17, 2013 10:28 am
I'm after an ultegra 52-36 6800 crank to run with my 6700 series transmission.
would this work?
There are no new unread posts for this topic. Shimano DA 9000 vs 9100 crankset
Grimpeur
28
2635
Fri Jan 05, 2018 12:29 pm
BdaGhisallo View the latest post
There are no new unread posts for this topic. Shimano Dura Ace 9000 free hub body backward compatibility?
BeeBee30
Wed May 17, 2017 7:32 am
petal666 View the latest post
There are no new unread posts for this topic. FC-9000 crank with 56-44 rings or just the rings
lactatehate
Tue Apr 18, 2017 3:13 am
FIJIGabe View the latest post
There are no new unread posts for this topic. Etap w/ Shimano crank
CrankAddictsRich
Sun Jun 04, 2017 9:31 am
dmoneysworks View the latest post
There are no new unread posts for this topic. Attachment(s) Simple, safe and tough components that save weight.
Lewn777
26
4057
Sat Jun 24, 2017 2:14 am
BikeAnon View the latest post
Users browsing this forum: Bing [Bot], Google Adsense [Bot], Hastur, PSJoyce, tetedecourse and 21 guests
