It is currently Wed Jan 17, 2018 2:13 pm
Post new topic  Reply to topic  [ 9 posts ]
PostPosted: Wed Sep 11, 2013 10:20 am
Maybe someone has the answer, because I haven't been able to find it anywhere.. I've seen people do this conversion for the record/chorus 10 speed versions, are these conversions possible in the new 11 speed systems? I've heard the Chorus 11 front derailleur has an integrated clamp, so I guess in that case it would be impossible right?.. is this also the case for Record 11 and Super Record 11?
Thank you!
Axel
PostPosted: Wed Sep 11, 2013 11:50 am
It used to be with 8, 9 and 10 speed Campy FDs that the integrated clamp was removeable via two small bolts. Take those bolts off and the clamp could be slid off the FD body and replaced/swapped out with the braze on attachment.
Later 10 speed and now 11 speed FDs seem to have all gone to pins that have no mounting bolt and that cannot be easily removed; trying to remove them might destroy the pin from what I see. This design change probably reduces weight a bit, but makes swapping FDs between different bikes more problematic. In general, I just buy braze on FDs and mate it with a light aftermarket FD clamp. The short answer is that I believe you can't easily convert the new Campy FDs from clamp-on to braze-on.
PostPosted: Wed Sep 11, 2013 3:24 pm
I'm afraid Stolichnaya is correct. In the current range only the 10s Veloce can be converted that way.
PostPosted: Wed Sep 11, 2013 4:04 pm
Thank you very much. That's the info I was looking for.
I am trying to find a NOS SR11 2010 braze-on front derailleur but I can only find the clamped version or if braze-on, only 2012 and later :(
I'll just have to play the waiting game hehe
Axel
PostPosted: Thu Sep 12, 2013 11:02 pm
You may be able to convert a veloce mech but you have to buy another front mech to do the conversion so what the point. All frames should have a braze on or buy a braze on adapter. that way you will never have this problem.
www.thecycleclinic.co.uk
PostPosted: Tue Oct 22, 2013 6:26 am
I don't have this problem. My problem is that it's really hard to find a braze-on NOS super record rear derailleur with the white logos, but there are plenty of those available in clamp format... Anyway I found one after a while, used in excellent shape, but it surely was the component that was the hardest to get...
PostPosted: Wed Oct 23, 2013 2:08 am
Does anyone know if 2007 Chorus front der, (clamp on) can be converted to braze on as well? I think/hope so. Im tired of the flimsy Record "carbon" one that has no rigidity and wanted to swap it to an all metal cage like the chorus.
My wallet is the lightest thing on my bike.
PostPosted: Wed Oct 23, 2013 9:04 pm
@gitsome, yes no problem converting a 2007.
PostPosted: Sat Oct 26, 2013 3:39 am
Thanks. Also do you know then if the same 2007 Chorus clamp-on (to be converted to braze-on) was configured/optimized for stand+compact together (like Record was) or were there 2 separate cage designs for the Chorus?
Any info is very much appreciated
There are no new unread posts for this topic. 2018 CAMPAG HO RD vs 2015 CAMPAG RD
wwnick
Wed Jul 19, 2017 9:11 am
wwnick View the latest post
There are no new unread posts for this topic. Supersix Evo braze on replacement
nickf
Tue Aug 01, 2017 9:13 pm
androidavies View the latest post
There are no new unread posts for this topic. eTap Red frt derailleur - will any braze-on adapter do, or must it be SRAM?
Digger90
7
277
Sat Jan 13, 2018 12:21 am
ikzzang View the latest post
There are no new unread posts for this topic. converting a ti bike to disc
markyboy
Sat Jun 10, 2017 1:05 pm
Tomstr View the latest post
There are no new unread posts for this topic. Converting flat mount to post mount
Miller
Wed Mar 01, 2017 11:55 am
Broady View the latest post
Users browsing this forum: Bing [Bot], crux, Look565w, MagicShite, MayhemSWE, michielkreutzer and 33 guests
cron
