It is currently Tue Jan 16, 2018 2:54 pm
Post new topic  Reply to topic  [ 11 posts ]
PostPosted: Mon Sep 09, 2013 6:17 pm
Ok you must not ride untested wheels by UCI on UCI races.
Bust we saw some prototypes and custom mades on Tour de France, Giro....
How this things go?
Could be custom build equipment used on UCI races?
http://kavitec.blogspot.com/
My NEED FOR SPEED ride:)
https://www.youtube.com/watch?v=8hhlPRud7oM
PostPosted: Mon Sep 09, 2013 6:28 pm
Ahh that would be the day. I wouldn't be surprised if UCI banned custom wheels entirely..
http://www.zencyclery.com
PostPosted: Mon Sep 09, 2013 6:40 pm
I wouldn't be surprised if someone produced UCI approval stickers as water-transfer decals. ;)
PostPosted: Mon Sep 09, 2013 11:29 pm
I am sure Mavic, shimano, camagnolo et.al would not want custom build wheels in UCI races which would be why UCI bans them. Silly really as it was not always this way.
www.thecycleclinic.co.uk
PostPosted: Tue Sep 10, 2013 12:55 am
if you're referring to froome's tune wheels in the tour then they don't fall under scrutiny as they're shallow depth.
PostPosted: Tue Sep 10, 2013 1:01 am
The way I understand the rules is that you can use whatever you want as long as it doesn't break the following rules:
-rims higher than 2.5 cm
-fewer than 16 spokes
-spoke thicknesses of over 2.4 mm
Anything out of those guidelines need to pass a rupture test and would be listed here:
http://www.uci.ch/Modules/BUILTIN/getObject.asp?MenuId=&ObjTypeCode=FILE&type=FILE&id=NjQxNjY&LangId=1
Explains why Wiggo and Froome were able to use AX-Lightness rims on mountain stages.
PostPosted: Tue Sep 10, 2013 9:07 am
Rims higher than 2.5cm? Implying no rims below 2.5 cm in height, I assume.
PostPosted: Tue Sep 10, 2013 9:50 am
Ambrosio Chrono, Nemessis are lower than 25mm----Paris Roubax
PostPosted: Tue Sep 10, 2013 10:47 am
For the 2014 season it appears that the UCI will remove the "standard" and "non-standard" distinction, and that (presumably) all new production wheels will need whatever new(?) testing is required to get them a UCI sticker?
http://www.uci.ch/Modules/BUILTIN/getOb ... k&LangId=1 (page12)
PostPosted: Tue Sep 10, 2013 11:09 am
No, opposite. A "standard" wheel has a rim with more than 16 spokes, a rim height of 25mm or less and the spokes no more than 2.4mm in width.
There is no reference to carbon vs aluminium though.
You can't be a real country unless you have a beer and an airline. It helps if you have some kind of a football team, or some nuclear weapons, but at the very least you need a beer.
-- Frank Zappa
PostPosted: Tue Sep 10, 2013 11:12 am
As a commissaire, it's a crap rule. A local amateur can turn up to race on some home built, 20mm carbon clinchers from china with hardly any spokes but someone who has rebuilt a 24 spoke zipp 440 with a new hub is technically not allowed to race on that wheel, despite it being probably stronger and probably safer.
-- Frank Zappa
There are no new unread posts for this topic. My Custom Build
callumghilton
Sun Mar 05, 2017 5:54 pm
kode54 View the latest post
There are no new unread posts for this topic. Rear Derailleur Pulley Wheels / Jockey Wheels - 17t and oversized sizes - where?
prendrefeu
27
1955
Wed Jan 03, 2018 3:28 am
morganb View the latest post
There are no new unread posts for this topic. Cav's custom paint job... 1g only
SixThirteen
28
4897
Mon Jan 08, 2018 3:28 pm
wingguy View the latest post
There are no new unread posts for this topic. Custom Frame Decals
SpecializedColnago
Fri Mar 03, 2017 9:49 pm
duvivr6 View the latest post
There are no new unread posts for this topic. Custom Stem Builder?
Lelandjt
9
580
Tue Jan 09, 2018 12:14 am
euph View the latest post
Users browsing this forum: Aya, Bing [Bot], coriordan and 33 guests
cron
