SRAM Red 2012 what FD..
rogan
by rogan
Hello all
I have a SRAM Red 2012 shifter set and rear mech the final 10 speed versions thats supposed to be with a YAW front mech.
I'm looking for a cheaper alternative to buying the rather pricey red YAW, i've seen that DA7900 works quite well, but I then remembered that the SRAM 22 sets are all YAW, so would a sram force 22 YAW front mech work..?
Thanks!
dcktr
by dcktr
the Yaw is a big step up. Worth the $$. I have yet to drop a chain. I would go to Shimano if you do not use the YAW.
2002maniac
by 2002maniac
I run a DA7900 with 2012 RED crankset and Stronglight CT2 rings. Shifts great (though I hear YAW is phenomenal)
rogan
by rogan
Cheers guys
i guess my main quesiton is, can i use SRAM Force 22 FD with sram red 10 speed shifters
Wookieopolis
by Wookieopolis
Force 22 FD will have a slightly narrower cage than the 10 speed Red Yaw FD. I'm sure it will work, but you will probably have to deal with some chain rub. Maybe run an 11 speed chain with it too?
theremery
by theremery
Just get a normal 10 speed Yaw Force...they're about 65USD on ebay :)
You can get a normal red to work but it's not perfect so DO go the YAW one
Updated: Racing again! Thought this was unlikely! Eventually, I may even have a decent race!
Edit: 2015: darn near won the best South Island series (got second in age
-group)..woo hoo Racy Theremery is back!!
rogan
by rogan
there isnt a force yaw fd thats not 22 unfortunately
johnsaysthisnow
by johnsaysthisnow
just got a force 22 FD to pair with my existing 10sp setup (rival) - If i get around to installing it in a timely manner along with the recabling I need to do, I can report back. I remember reading somewhere that, while the cage is a tad narrower than the 10 speed FDs, that they would work just fine with a 10 speed setup.
