Lightweight Meilenstein hub question
Lafolie
by Lafolie
Folks. Would anyone know if a Campagnolo free hub body from a Lightweight Standard 111 Clincher rear wheel fit the new Meilenstein Clincher ? Thanks
audiophilitis
by audiophilitis
I believe they're both equipped with DT190 hubs. Haven't heard of a change in hubs for the Meilenstein.
Lafolie
by Lafolie
cheers
CarbonSportsGmbH
by CarbonSportsGmbH
You have to check if you have a 10s wheel or a newer, 11s compatible, "11s" labeled wheel.
For older wheels you should only use 10s bodys (has nothing to do with the fact taht Campy is 11s for a long time, but with Shimano 11s last year we had to change widths of the freehub body and so the geometry of the wheel itself). Newer, 11s built wheels have a small sticker on the freehub side so they are easily to recognize.
The bodys are fully compatible!
Andreas Schiwy, CarbonSports GmbH
http://www.lightweight.info
support[at]lightweight.info
Lafolie
by Lafolie
thanks LW :-)
mnmasotto
by mnmasotto
Andreas,
What happens if i put a 11 speed shimano freehub on my Gen 3 clincher lightweight rims? My hub does not have the 11 speed sticker.
coppercook62
by coppercook62
Post subject: Re: Lightweight Generation 3Posted: Mon Aug 19, 2013 4:11 am
In Lightweight Standard Gen 1 - convert to Shim 11sp, HammerTime2 wrote:
In Lightweight Mellenstein, Andreas Schiwy, a.k.a. CarbonSportsGmbH wrote:
All Lightweight rear wheels will be compatible to Shimano 11s. The new production has modified hubs, and there will be new DT freehub bodies (marked as 11s). Four different combinatins wiil be possible:
10s wheel + 10s freehub body => 130mm wide, the well known setting up to now
10s wheel + 11s freehub body => 131mm, wheel is 0,5mm off center to the left, when using 21t or 23t cassettes derailler may contact spokes (only with sprint rear wheel)
11s wheel + 10s freehub body => 131mm, wheel is 0,5mm off center to the right
11s wheel + 11s freehub body => 131mm (spacer needed to use 10s cassettes here, spacer is part of purchased parts package)
HammerTime2 wrote:
So is there no spoke contact problem for all 10 speed Lightweight wheels other than sprint? What about Ventoux Gen. II or Gen. III with DT 240 or DT 190 plus new (11s) freehub? What are the consequences of being 0,5 mm off center?
- Ventoux could be critical as well, as they are 24spoked. The "contact area" are the knots where the spokes are bended together...
- 0,5mm off center does not really matter... many wheels come off center and you would never realise during riding. Lots of frames might be off center as well..
