Campagnolo package @ Ribble
So the best price I've found for a complete group is from Ribble.
They are offering Centaur with carbon levers for £460, or £560 with carbon cranks.
Is it worth the extra £100 to save 94g or would I be better off getting the aluminium version and then upgrading to an aftermarket crankset?
Campagnolo; because it's a bicycle, not a fishing rod.
Ive been impressed with Campy UT cranks. They seem like an overall good choice even in aftermarket terms. I would upgrade to the carbon and consider it done.
Casati Vola SLi and Dolan Preffisio
viewtopic.php?f=10&t=108931" onclick="window.open(this.href);return false;"
btompkins0112 wrote:
It has the H2 geo......one step racier than a hybrid bike
- MajorMantra
I'd get the alu cranks, sell them, and find an Ultra-Torque one instead. Power Torque is inconvenient.
I'd steer well clear of carbon p/t cranks as they're an absolute pain to remove without damaging them, the alu ones it's not so much of a worry. Like others have said I'd perhaps buy the cheapest option then look for a bargain on some carbon u/t cranks instead.
Centaur hasn't been UT for years so good luck finding stock. PT is very easy to install (once you have a 14mm hex key). If you need to uninstall get a friendly LBS to do it or buy a bearing puller, there are threads on here describing this. I have done one PT uninstall on an Athena carbon crank and it was very straightforward, using a rag to protect the carbon surface. If you're mechanically competent don't be put off.
I'd go for the Centaur carbon if you can.
- MajorMantra
The problem with PT is that you either need to spring for some costly tools or try to figure which gear puller can be bodged to work. This irritates me.
MajorMantra wrote:The problem with PT is that you either need to spring for some costly tools or try to figure which gear puller can be bodged to work. This irritates me.
What costly tools are that? Disassembling and assembling UT cranks is a piece of cake. You need the bb tool and the tool for the centernut in the crankset, done?
The unbearable wallet lightness of being a weightweenie
- MajorMantra
PT not UT.
That's true for carbon. If you want to buy UT centaur carbon, the only resource here is ebay and a good bit of luck. I've seen plenty of alloy Centaur UT in ebay for cheap however.
Miller wrote:Centaur hasn't been UT for years so good luck finding stock. PT is very easy to install (once you have a 14mm hex key). If you need to uninstall get a friendly LBS to do it or buy a bearing puller, there are threads on here describing this. I have done one PT uninstall on an Athena carbon crank and it was very straightforward, using a rag to protect the carbon surface. If you're mechanically competent don't be put off.
- Similar Topics
- Replies
- Views
- Last post
Campagnolo 11 speed using 34/50x11/36! Yes it can be done with PRE-2015 Athena LC Big Gears on Campagnolo 11 speed
by colnagoaddict » Wed Aug 23, 2017 8:32 pm » in Road - 21 Replies
- 2468 Views
Last post by alcatraz
Wed Feb 28, 2018 1:39 pm
- 9 Replies
- 1020 Views
Last post by graeme_f_k
Sun Jan 21, 2018 4:12 pm
- 3 Replies
- 729 Views
Last post by BRM
Wed May 31, 2017 2:23 am
- 7 Replies
- 1496 Views
Last post by garjo
Tue May 30, 2017 11:48 am
- 6 Replies
- 1015 Views
Last post by spookyload
Thu Aug 31, 2017 6:53 am
