It is currently Tue Jan 23, 2018 3:33 am
Post new topic  Reply to topic  [ 7 posts ]
PostPosted: Fri Aug 30, 2013 4:42 am
Hi all, posted this on slowtwitch, but thought Id check here as well, as I know lots of folks here have experience with powertaps.
I recently purchased two -new- sets of Mavic Cosmic Carbone Pro Powertap wheelsets. Both were the older 2.4 SL versions, so I purchased the updater for them, which indicated that it ran successfully for both (to make both ANT+ compatible).
However, when I try to pair with my 910XT, nothing seems to be happening. I go to the bike 1, select powermeter, yes, and restart calibration. Then it basically shows nothing, even as I spin the wheel... Same deal with a EDGE 500..
I did also put new batteries in both hubs.
Next, tried the little yellow computer that came with each wheel. Started by replacing the battery in each as they were dead.
Go to the 'learn' thing, spin the wheel, neither can detect the hub. WTF?
I did call Saris, and they said I could send the wheels in. That is great, but I'm in Canada, and pretty sure they aren't offering to cover the $100 it will cost to ship them (yup, UPS or Purolator ground, $100 give or take....). Not sure about shipping back to me..
How can two brand new out of the box wheels not work? Wondering if the updater, even though it flashed green for success, actually screwed both hubs up?
Anyone else go through this?!?
Help!
PostPosted: Fri Aug 30, 2013 8:40 am
I would recheck the full battery specification (not just the size). Older 2.4s had a slightly unusual battery spec.
Sorry if this has been done already, but worth a try. I had various 2.4s that were sensitive to battery.
Good news is that the newer model seems better in most regards, and that PT will respond if you push and push.
PostPosted: Fri Aug 30, 2013 8:43 am
Try the update again.
"Step forward the climber and all those who worship at the altar of lightness" - R. Millar
PostPosted: Fri Aug 30, 2013 3:34 pm
The ANT updater? It only has two updates, used one for each wheel. Did try plugging it into one of the wheels again anyway, but it just flashed red since it had already been used.
PostPosted: Fri Aug 30, 2013 3:45 pm
Ah thought you had two updaters. Was banking you'd hadn't done two updates with one
PostPosted: Fri Aug 30, 2013 5:59 pm
Try reseating the battery holder. Make sure you can feel that it is properly aligned, then wiggle it into place and push it home solidly.
Make sure the wire loop on the holder is sticking straight out. It is an antenna.
Might as well put in a fresh pair of batteries once you open it up again, just to remove that as a variable.
Mine are SL+, so I never had to do the "updater".
PostPosted: Fri Aug 30, 2013 6:03 pm
Thanks, will try it again tonight.
There are no new unread posts for this topic. Syncroshift not Working...Thoughts?
merlin3008
Sat May 27, 2017 3:57 pm
fasdflkjweorinjs View the latest post
There are no new unread posts for this topic. V3 EPS Updates Not Working Via MyCampy
RichTheRoadie
15
1545
Tue Dec 12, 2017 7:02 am
TonyM View the latest post
There are no new unread posts for this topic. DI2 suddenly stopped working???
cunn1n9
Tue Jan 23, 2018 12:10 am
pdlpsher1 View the latest post
There are no new unread posts for this topic. Powertap P1 Pedals
mattCSUK
Fri Feb 24, 2017 5:41 pm
Butcher View the latest post
There are no new unread posts for this topic. Powertap G3 lock nut
robsbc
Thu May 25, 2017 3:16 pm
fio View the latest post
Users browsing this forum: alcatraz, Baidu [Spider], Bing [Bot], Google Adsense [Bot], hannawald, praem, Zitter and 39 guests
