It is currently Mon Jan 22, 2018 5:45 am
Post new topic  Reply to topic  [ 5 posts ]
 Post subject: Bmc slr01 cups (2011)
PostPosted: Mon Aug 26, 2013 1:38 pm
Hi there i am a bit confused, i have a bmc slr01 2011 frame, there is bb30 but mine seems like standard cups :noidea:
then i see this link with the 2011 bike and a photo tha clear we see bsa bottom bracket, what cups i need ???
:noidea: :noidea: :noidea: :noidea: :noidea: :noidea:
http://road.cc/content/review/47665-bmc ... hine-slr01" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;
''Due to some longevity issue negative feedback BB30 is being dropped on the 2012 models to be replaced with BB86. Mind you, as BMC are moving towards Shimano for 2012 the BB30 would have had to go anyway. Our frame is fitted with adaptors to allow standard Shimano outboard bearing cups to be fitted to the BB30 'hole'. This means a slightly larger Q factor compared to the press fit BB30 & 86 versions though''
and thats mine
BMC Teammachine Slr01
www.jabik.gr
http://instagram.com/banik69
PostPosted: Mon Aug 26, 2013 2:49 pm
the picture is not all that clear, but looks like bb30 to bsa adapter
is there threads in there ?
PostPosted: Mon Aug 26, 2013 2:55 pm
Yes it is threads in there, this bsa adapter is permanent ???
So i need bottom with threads, correct ?
www.jabik.gr
PostPosted: Mon Aug 26, 2013 3:27 pm
yeah bsa most likely
can you measure outside to outside with a slide measure, it seems to me these adapter have added quite a bit of width to the bottom bracket shell
the value we are looking for should be close to 68 mm
PostPosted: Mon Aug 26, 2013 3:34 pm
Μmmm thanks, i dont have problem if is bsa....i just spoke with a friend and told me that is bb30 with bsa adapter, i dont know why but is ok. Also told me that i want now is rotor bb1 bottom bracket to match with rotor 3d crank...
www.jabik.gr
There are no new unread posts for this topic. Campagnolo UT SR BB Cups - difference between 2011 and 2015 versions?
RJKflyer
Tue Apr 11, 2017 9:49 pm
Calnago View the latest post
There are no new unread posts for this topic. new BMC SLR01
addictR1
Wed Oct 18, 2017 5:32 pm
PinaF8 View the latest post
There are no new unread posts for this topic. Campagnolo SR ITA BB cups installation method
karhu
14
872
Mon Jul 03, 2017 11:15 pm
AJS914 View the latest post
There are no new unread posts for this topic. Attachment(s) Cdale Evo Hi-Mod vs BMC SLR01 vs AX Evo vs AX Evo Race
dereksmalls
Wed Jan 10, 2018 9:58 pm
dereksmalls View the latest post
There are no new unread posts for this topic. Tarmac SL6, Madone 9, F10, or SLR01 Disc...
mile2424
19
2036
Mon Oct 23, 2017 5:17 pm
MRM View the latest post
Users browsing this forum: Baidu [Spider], kookie and 37 guests
