It is currently Wed Aug 23, 2017 10:38 pm
Post new topic  Reply to topic  [ 13 posts ]
 Post subject: BB - Chris King or HSC
PostPosted: Mon Aug 26, 2013 4:39 am
I'm building a new bike which has a BB86 frame. What do you guys think between:
Chris King Press Fit 24 - Steel (c. $140)
Chris King Press Fit 24 - Ceramic (c. $210)
HSC Ceramic BB86 ($135 - http://www.hscceramics.com.au/HSC-Bike- ... -BB86.html" onclick="window.open(this.href);return false;)
The HSC seems to have good specs from what I can tell, and it's also 30g lighter than the CK ceramics. The CK reputation is indisputable though. Help :welcome: .
Thanks!
PostPosted: Mon Aug 26, 2013 6:13 am
Never used BB86, but I can speak/write about HSC bearings and they are fantastic. I've used them on both BB30 and BSA/external cup frames.
PostPosted: Mon Aug 26, 2013 12:04 pm
im no expert but I can tell you i had a bad experience with a HSC GXP bottom bracket a few years ago, from memory the tolerances were out and they kept coming loose, I returned them and got my money back
was told by my lbs they are just chinese made bearings imported by an aussie company and to try these American made bearings http://www.vcrcbike.com/ havnt had a problem since
prendrefeu has had great experiences so maybe I was unlucky and got a dud set
PostPosted: Mon Aug 26, 2013 3:46 pm
I'd also recommend VCRC. I have a set (GXP, ceramic) and they are very smooth.
PostPosted: Mon Aug 26, 2013 9:25 pm
If I weren't running an FSA K-Force SRM which has a slightly larger diameter spindle than Shimano forcing us to use FSA parts, I would be using a KCNC Press-In BB86 Bottom Bracket.
PostPosted: Tue Aug 27, 2013 3:32 am
I will vote for HSC. I have them on two bikes now and have installed them in friends bikes. Primarily PF30 and BB30 with never an issue.
PostPosted: Tue Aug 27, 2013 1:02 pm
Another vote for VCRC
PostPosted: Tue Aug 27, 2013 1:37 pm
Ive had a kcnc bb86...poor tolerances.noisy.
Binned it....
Im usually a fan of kcnc,as well...:sad:
Sent from my GT-I8160 using Tapatalk 2
tcr's rule !
stefanpearce@rocketmail.com
PostPosted: Wed Aug 28, 2013 6:02 pm
I have a ceramic Chris King BB (Shimano) with < 2000 miles on it, and it's already making grinding noises. Not happy with CK at all.
My favorite components are the ones I never have to think about.
PostPosted: Wed Aug 28, 2013 7:08 pm
I have a CK 68mm along with the grease injection tool. Just based off of feel, I thought the bearings were nothing compared to the Campy SR I had on my bike before. I only made the switch because I was installing a Quarq. Every time I used the tool it would force the gaskets to pop out, and in general I just felt the CK "name" was hype.
I've since had a Quarq warranty replacement, and now since I am using the Elsa I have a SRAM GXP bb... I'd be interested switching to VCRC or HSC is truly an upgrade.
"Deserve's got nothing to do with it." William Munny
PostPosted: Wed Aug 28, 2013 7:12 pm
The VCRC ceramic GXP is an upgrade from the Sram steel bearing GXP but the Sram one is so good that it's only a small difference in the "spin the cranks" test.
I realize that test is not representative of actual use but its what I have available.
PostPosted: Thu Aug 29, 2013 4:11 am
Thanks. I understand the "spin" test is not very scientific, but what else do we have? I know when I gave the Campy setup a whirl it was remarkable. The Chris King... bleh! It seems I spent a lot of time trying to tighten the crank "just enough" to avoid play but get some freedom in its rotation. In that sense, the GXP is a nice switch. Just tighten and go. No fiddling.
PostPosted: Thu Aug 29, 2013 2:35 pm
I think the GXP is the best design for external bearing cranks. Less tools, no preload problems, self extracting, etc.
For certain parts stiffer is more important than lighter.
There are no new unread posts for this topic. Chris King R45 Campagnolo hub problem?
wilwil
7
587
Mon May 29, 2017 1:14 pm
wilwil View the latest post
There are no new unread posts for this topic. Will the new Chris King T47 Bottom Brackets fit on my THM SE cranks?
kode54
Fri Mar 31, 2017 3:37 pm
Denavelo View the latest post
There are no new unread posts for this topic. Chris King Gold Color - Seatpost Clamp?
Nejmann
Sun Sep 11, 2016 12:48 am
froze View the latest post
There are no new unread posts for this topic. Spoke length for Enve 3.4 wheel with Chris King R45 hubs?
kode54
Mon Jan 02, 2017 3:28 pm
kode54 View the latest post
There are no new unread posts for this topic. Destroyed Chris King R45 Rear Hub - Your Expert Opinion Solicited UPDATED
beeatnik
23
3333
Thu Feb 09, 2017 2:21 am
MJB View the latest post
Users browsing this forum: benjaminm3, etownfwd, Gearjunkie, ghisallo2003, glam2deaf, hilts, mriddle, Mtek, RichTheRoadie, wedgie, Yahoo [Bot], youngs_modulus and 47 guests
