It is currently Mon Apr 24, 2017 4:36 pm
Post new topic  Reply to topic  [ 56 posts ]  Go to page Previous 1 2 3 4 Next
PostPosted: Sun Feb 02, 2014 4:54 pm
Dammit wrote:
Is anyone running an Ionic post with an Arione R1?
I'm running this setup and it works fine. But you have to get the oval caps. No creaking.
PostPosted: Tue Feb 04, 2014 2:06 pm
Running the Ionic 25mm set back with the selle italia slr carbonio. Seems to be working fine even though the customer service rep said it wouldn't work.
PostPosted: Tue Feb 11, 2014 7:14 pm
I'd like to add my experience to this thread:
I bought a new 0 setback Ionic to go on my Cervelo R5 because, like a lot of you, I thought it was a great looking post. It came with both the round and oval clamps. I found that the oval clamps did not firmly hold a 7x9mm Specialized Toupe carbon rail, so I emailed 3T's customer service about the issue. After a bit of back and forth, I received a new, tigher-fitting clamp kit for oval rails, and although it was a bit better than the first, it still was not a secure fit.
I have a Bontrager carbon-railed saddle that I'm pretty sure is 7x10 and it fits fine. I suspect that a Selle Italia carbon-railed saddle, which I think is 7x9.6 would also work with the 3T clamps, but I haven't proven that.
Anyway, my conclusion is that 7x9 doesn't work, which is a pity because it's a very slick-looking seatpost, but anything larger than that is a good bet. I'll probably be putting mine on ebay.
Chris
PostPosted: Tue Feb 11, 2014 7:26 pm
I bought an Enve instead and the clamping mechanism is sliding so it will accommodate a small variation in rail dimensions. The clamp is also slimmer which solves the problem with the Ionic extending beyond the shape of the saddle. It will for sure be polish with time.
It's online again:The Machinist
My CAAD10:http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=109014
PostPosted: Wed Feb 12, 2014 12:58 pm
Huh? The Enve ships with two sets of clamps, one for regular rails, one for carbon rails.
My RCA
PostPosted: Wed Feb 12, 2014 8:24 pm
Yes but what I'm saying is that the carbon clamps will fit carbon rail that deviate from exactly 7x9mm, that being for example Fizik or Selle Italia rails. The standard clamps only fit 7mm round rails.
PostPosted: Wed Feb 12, 2014 10:45 pm
Ok.
My RCA
PostPosted: Thu Feb 13, 2014 8:27 pm
I can tell you that the Ionic oval clamp does not work effectively with Selle SMP carbon rails. There is play and the seat will slide back when doing hard seated climbs. Had to go back to steel rails which work fine.
Great seatpost for looks and love difflock as once it's set up then you never need to change it. But I think you have to accept that your going to be using steel rails....
PostPosted: Tue Apr 29, 2014 9:41 pm
I seem to have the same issue, just email 3T. I've paired the 3T Ionic - 0 with oval caps with a Selle Italia Flite gel w/ Ti ovalized rails (7x8mm) The saddle slid back and went nose up causing some unwanted numbness on my last weekends metric century...
Waiting to see what 3T has to say, I sad to be a little un-optimistic... :(
PostPosted: Tue Apr 29, 2014 10:46 pm
I'm in a similar position with my new Felt AR1 seatpost. It came with the 3T difflock seat clamp mechanism and I realised pretty quickly I'd need the oval clamps for my Specialized Toupe pro 7x9 rails. Currently waiting on the parts arriving from 3T in Italy, I'll report back with my findings.
Really hoping it fits as I don't want to have to change saddles.
PostPosted: Wed Apr 30, 2014 8:27 pm
Update from me. I received the clamps today and they don't fit. I can see what the issue is though and I aim to sort it tomorrow. The caps are too long to allow the clamps to tighten enough to hold the saddle tight. This may be an issue unique to the AR1 3T seat post which I have. I reckon if I file the end of the caps enough I should be able to get enough torque on the rails for it to be tight.
The caps are hitting the teeth on the inside of the hole of the seat post so if I file it slightly i'm hoping it will fit.
PostPosted: Fri May 02, 2014 5:34 pm
Ok after filing the end caps it's still not torquing up for me. The weird thing is if I take the difflock mechanism out of the seat post it tightens up no worries. The only thing I can think is that the red barrel that the rails sit on is a different shape for the oval clamp.
Can anyone confirm or deny this? I did just buy the end caps from 3T thinking that would do the job, but now thinking I may need to but the caps and the red barrel. Might be cheaper just to buy a new saddle......
PostPosted: Fri May 02, 2014 5:44 pm
With the Palladio seat posts, you had to buy a new spline with the cap for oval rail compatibility, that was fixed with the new Ionic. Perhaps your design is similar?
PostPosted: Fri May 02, 2014 6:35 pm
Looks like it could well be the case. It's a brand new bike for this year though so I would have thought it should have had the new splined part included.
Any way to know if it's the new one or the old one?
PostPosted: Fri May 02, 2014 11:33 pm
Online
Just to put in my 2 cents... I bought an S-Works Toupe carbon railed saddle so I ordered the oval clamp for my Palladio seatpost from 3T. I tried it out for 10 minutes on my trainer and it scuffed the rails slightly. Fail. There was just enough gap to allow the rails to move under load. I ended up buying an Enve post and the included oval clamps worked perfectly without a hassle.
There are no new unread posts for this topic. 3T Ionic 0 LTD Seat Post Diff Lock Break
lw11
16
642
Sat Apr 15, 2017 2:15 am
DuncanS View the latest post
There are no new unread posts for this topic. Carbon saddle not fitting
rbynck
Fri Aug 12, 2016 9:12 pm
TheKaiser View the latest post
There are no new unread posts for this topic. lowest stack carbon saddle
InoxEPS
7
819
Tue Oct 18, 2016 1:36 pm
metabo View the latest post
There are no new unread posts for this topic. Interesting New Carbon Saddle - Rido LtX
alistaird
Wed Oct 26, 2016 5:54 am
alistaird View the latest post
There are no new unread posts for this topic. Flat profile full carbon saddle w/cutout
nickf
7
885
Tue Jul 26, 2016 4:18 am
NGtim View the latest post
Users browsing this forum: Baidu [Spider], bikemaniack, Bing [Bot], djwalker, evan326, gewichtweenie, nafaiutb, shadowman, trex021 and 35 guests
