It is currently Fri Jan 20, 2017 7:31 pm
Post new topic  Reply to topic  [ 56 posts ]  Go to page Previous 1 2 3 4 Next
PostPosted: Mon Aug 26, 2013 8:37 am
Is it comfortable? Often strait seatpost tend to make some vibrations...
PostPosted: Mon Aug 26, 2013 8:45 am
Tinker, Taylor, Tart
245km this weekend with no discomfort - even on the K:1 saddle (which can be firm on long days).
PostPosted: Mon Aug 26, 2013 9:25 am
:thumbup:
PostPosted: Mon Aug 26, 2013 12:01 pm
Rich thanks for taking the time to post pics....... it does indeed look very good.
PostPosted: Mon Aug 26, 2013 12:38 pm
1415chris wrote:
Have you had a chance to put it on the scale?
27.2 x 350 = 192g
PostPosted: Mon Aug 26, 2013 2:18 pm
BikeTart wrote:
3 shots of the post in attempt to show how clean and smooth the lines are
I agree with your assessment, just wish it was not so time consuming to get the desired saddle angle. One observation - I would think that post might be problematic for the Fizik Kurve series as it seems that the slight flex in those saddles could bottom on the top of the seat post.
PostPosted: Mon Aug 26, 2013 2:44 pm
BikeTart wrote:
The only cleaner looking post on the market is the Enve.
Yup. And Enve comes with both sets of hardware and works perfectly with my Sworks Toupe carbon rail saddle.
My RCA
PostPosted: Mon Aug 26, 2013 3:07 pm
But once you get it set, it's not going to move/change.
If you change saddles, just mark the pieces with 3 dots (inner,outer,post) so you can quickly reinstall them to the same angle as before. Different saddles = different color dots.
PostPosted: Mon Sep 09, 2013 12:04 am
my friend and I are having problem with the IONIC.
It keeps squeaking/creaking while you put torque on climbing/sprint.
I may try with my other saddle as soon as the Oval Mechanism arrive.
anyone has the same issues? :noidea: :(
PostPosted: Mon Sep 09, 2013 12:07 am
No creaking here - mine's been fine since I modified it to work with the carbon rails.
PostPosted: Mon Sep 09, 2013 1:11 am
No creaking here...
PostPosted: Mon Sep 09, 2013 5:31 am
What color your inner spine for round rail?
Black or Red?
Mine is Red, from the look of the shape is for OVAL rail.
I should have Black inner spine for round rail.
Looks like they sold us OVAL inner Spine with Round rail cap :(..
PostPosted: Mon Sep 09, 2013 5:49 am
Not so for the Ionic - it's been simplified a little so that it's only the end caps that differentiate between round or oval now.
In fact I think the same now applies for the Palladio too.
FWIW, with the red insert (oval, by your reckoning) my Ionic didn't creak with round rails either.
PostPosted: Sun Feb 02, 2014 12:15 am
Is anyone running an Ionic post with an Arione R1?
PostPosted: Sun Feb 02, 2014 8:09 am
After returning the Ionic as I couldn't get to work with my Specialized Romin Pro saddle with 7x9 rails
I bought a Cranbrothers Cobalt 11 with the 7x9 kit. It has the exact same problem as the 3T Ionic. After some emails forth and back they finally informed me that the saddle was designed only for the Fizik saddles with the wrapping. These are more like 10x8 which is of cause why it can't be clamped down. The wrapping is there to prevent stress points on the carbon rails and adapts to the cups, so it need to fit a bit tigth in the clamps. Well the end result was that I found some fiber tape and wrapped that on the rails with an overlap as to get the right thickness. It seems to work, but will be verified on the road in a couple of months when the snow is gone and the roads are dry.
It's online again:The Machinist
My CAAD10:http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=109014
There are no new unread posts for this topic. Carbon saddle not fitting
rbynck
Fri Aug 12, 2016 9:12 pm
TheKaiser View the latest post
There are no new unread posts for this topic. lowest stack carbon saddle
InoxEPS
7
757
Tue Oct 18, 2016 1:36 pm
metabo View the latest post
There are no new unread posts for this topic. Interesting New Carbon Saddle - Rido LtX
alistaird
Wed Oct 26, 2016 5:54 am
alistaird View the latest post
There are no new unread posts for this topic. Flat profile full carbon saddle w/cutout
nickf
7
764
Tue Jul 26, 2016 4:18 am
NGtim View the latest post
There are no new unread posts for this topic. Retro look saddle with high saddle top to rail height
Steno
Sun Feb 07, 2016 4:28 am
em3 View the latest post
Users browsing this forum: 3Pio, 5 8 5, Bing [Bot], CBRE, Delorre, ninjabrewer, SL1, victorduraace, wingguy and 31 guests
