-8deg stem in wet/gloss finish
digitalnorbs
by digitalnorbs
can some one recommend a stem brand that is kind of like zipp sl model, but in -/+8 deg vs zipps -/+6deg
Getter
by Getter
Deda...
shimmeD
by shimmeD
Whatever happened to all the 8deg stems? Thomson had them (in a big range) and so did Rotor, in gloss black.
Thomson's 10deg might do you as the stack height is 36mm compared to the 'normal' 40-42mm. It's a little porky however.
Less is more.
digitalnorbs
by digitalnorbs
I did check deda and i dont see anything in gloss black, love Thomson but its not gloss like zipp=(
shimmeD
by shimmeD
Have you seen the Thomson in person? Not perfect match to gloss black, but it's good enough for me against Ritchey wet black bars.
Less is more.
yourdaguy
by yourdaguy
Ritchey WCS 260 comes in Gloss Black and even the faceplate is gloss.
For certain parts stiffer is more important than lighter.
corky
by corky
Tune... not gloss but more satin as it's anodized.
Extralite.... as above
