Custom Bar/Stem
Berk
Carbon Cowboy
by Berk
@dcktr, BmanX, KB
Thanks!
Unfortunately I don't have more photos, but the bar that was used for this combo is a Zipp SL. Otherwise any other bar could be used (the same goes for the stem, but it has to be carbon).
Berk PROTO-TYPE Composites - Handmade In Slovenia
Berk Composites
http://www.berk-composites.com/
info(a)berk-composites.com
BmanX
by BmanX
Jure - were you reading my mind? Seriously I was just going to ask if you could bond an aluminium stem to a carbon bar like Ruegamer used to do.
I have an older 26.0 carbon Easton bar that I would like to have bonded and will have to PM you about it soon.
BIG DADDY B FLOW
AERO & LIGHT is RIGHT
Cervelo SLC 5960g/13.13 lbs
Berk
Carbon Cowboy
by Berk
Well I rather avoid bonding ALU/carbon because well known reasons (different material properties), could of course bond also an ALU stem. Otherwise, if bonding with ALU, the Ritchey C260 stems with their clamping system would be perfect, no need for that much extra carbon reinforcements and it's also not an expensive stem...otherwise also the complete stem can be covered with the same cosmetic layer,..
Berk Composites
jpanspac
by jpanspac
Aluminum and carbon fiber don't play nice together. Google galvanic corrosion.
My favorite components are the ones I never have to think about.
DMF
by DMF
Zipp Vuka Sprint with Zipp SL145 by Experimental Prototype in Sweden, there is an integrated computer mount hidden under the bar/stem. The stem and bar interface is wrapped together in a string-like carbon and finished off in multiple layers of Textreme, the hidden mount is all titanium beneath the carbon cloth. All finished in ten layers of a high gloss clear coat.
prendrefeu
by prendrefeu
Looks pretty nice. Is the final weight less than the same stem/bar combo with normal faceplate and bolt application?
Mattias Hellöre
by Mattias Hellöre
In this case with ZIPP products, I dout it weighs less, stiffer yes which was the target.
As mentioned before I´ve done a 217 gram combo which held up fine for EN testing protocol once.
Mattias Hellöre
by Mattias Hellöre
The textreme layer is visible here.
DMF
by DMF
Yes, as Mattias Hellöre said, focus was on stiffness and it would in my view be a bit unfair to do a direct weight comparison as there is a also a long titanium plate baked in there for a soon-to-come Garmin in-front mount which adds some weight.
This project was done for aesthetics, stiffness and perhaps having fewer parts on the bike. I like integration where it is practical.
prendrefeu
by prendrefeu
Excellent work Mattias!!
