It is currently Mon Dec 18, 2017 10:18 am
Post new topic  Reply to topic  [ 1296 posts ]  Go to page Previous 157 58 59 60 6187 Next
 Post subject: Re: Felt 2014 AR1
PostPosted: Fri Jun 13, 2014 6:17 pm
I'll take pictures...Maybe this weekend. I'm set to pickup my Di2 group this afternoon, and plan on building it up and riding it as much as I can this weekend, since I can use the it's father's day excuse :)
Ya - Frame came pretty quick. It showed up a day or two after I ordered...can't really complain.
Was initially planning to upgrade over winter. But then while looking at pictures online I stumbled across a 58 FRD frame in stock at Irvine Cycles, and was waffling between getting an AR3 and probably putting Dura Ace on it vs waiting and ordering an FRD for '15. I asked the local shop if they could get the 58 from another dealer, and he checked Felt's stock on the FRD first, and saw there was one available. I ordered it on the spot ;) Long story short, I feel like I got lucky with availability....and am building the FRD with ultegra rather than an AR3 with dura ace - should come out about the same initial weight.
I'm replacing a venge and a tarmac with the AR - nice to see that others have done the same and are happy.
PostPosted: Fri Jun 13, 2014 7:01 pm
Nice. Should be a great weekend to get a nice first ride on it. Look forward to hearing your review.
I have also been slowly picking up 6870 parts in anticipation of a build. Was contemplating going with 9070 shifters as that would save ~75g. But not sure I can justify the price difference it would cost. I was able to pickup the 6870 shifters new for $180 with a discount I had. Cheapest 9070 shifters I have been able to find is ~$500. $320 to save 75g, comes out to $4.27/g.
PostPosted: Fri Jun 13, 2014 10:21 pm
I was visiting Irvine bike and they have an AR- FRD in stock- 54cm for anyone still hunting. If it was a 56 I would have bought it.
PostPosted: Sat Jun 14, 2014 11:34 am
Mine arrived last week
PostPosted: Sat Jun 14, 2014 4:08 pm
Looks great trilocus. Look forward to the complete build.
It must be the angle of that picture but I thought the downtube was dropped closer to the front wheel. That picture for some reason makes it look like a fairly large gap.
PostPosted: Sat Jun 14, 2014 4:24 pm
Is that a very small frame?
Either way I agree that thing is sharp looking.
Just ride ..
http://1k2go.bigcartel.com
https://www.instagram.com/itsacarr
https://www.strava.com/athletes/1044522
PostPosted: Sat Jun 14, 2014 4:33 pm
The bike is being building by my lbs. The picture is crap.
No a small frame, the size is 54 but the seatpost is very high and the fork has a lot of spacer and is uncut
PostPosted: Sat Jun 14, 2014 5:36 pm
Did you have a chance to weigh the frame and fork before having the shop built it up?
PostPosted: Sat Jun 14, 2014 5:48 pm
With all the hardware and bolts and the plastic routing cables
Uncut fork
Sorry but i forgot to weight the seatpost
PostPosted: Sat Jun 14, 2014 6:09 pm
Interesting. Thanks for sharing the weights.
SuperDave mentioned the weight as being around 900g and fork 325g for the AR FRD in a target size 56.
MODEL FRAME / FORK
AR FRD 900g / 325g
AR1, AR3R 1050g / 350g
AR2, AR3E 1000g / 350g
AR4, AR5 1100g / 375g
Surprised to see FRD at 1037g/334g.
A AR1 posted earlier came in at 1071g/335g.
PostPosted: Sun Jun 15, 2014 2:41 pm
yes something looks wrong, my 58cm came in at 1032g. my fork was 328g uncut.
PostPosted: Sun Jun 15, 2014 5:11 pm
Can anyone give me a summary of why Oxeon's TeXtreme spread tow carbon fiber is so great and worth the price upgrade over the AR1 frame? I know the TeXtreme is very expensive, hard to get, hard to get to your manufacturing facility, comes from Sweden, is lighter, is stiffer, is more resilient to impact, is used in F1....etc.
But at the end of the day, why do I want a TeXtreme carbon fiber bike and not one made from UHC Advanced MMC carbon fiber?
SuperDave wrote:
I'm unclear why you'd opt for the high end frame (AR FRD) if it were mechanical shifting compatible but not the high end frame that is (AR1)? I'm also suprised that you're looking for an aero advantage but willing to give up the ~7-10 watts shift cables add.
Is it really 7-10 watts (70-100g) just for mechanical cables and the airflow disruption that causes? The AR has a total drag of 600-700g, just surprised that 10-17% of the frames drag could be related to just going mechanical over Di2.
theloper wrote:
Was this frame designed to be optimized with bottles and cages in place? It doesn't appear so. Frames like the Giant Propel and the Cervelo S5 have flared air foil down tubes to accommodate bottles. Was any of your wind tunnel data with bottles on your frame as well as your competitors you tested (Giant , Cervelo, Scott, etc.) ?
Any ideas on this one? I haven't seen an answer to this. Based on the shape of the downtube, I assume it was not optimized for bottles and cages in place. I assume Felt will add this feature on the 2016 or 2017 AR frame?
PostPosted: Sun Jun 15, 2014 6:39 pm
Just for future reference, here is another Felt AR FRD, this one in a size 58cm.
1052g/328g
So far have a AR FRD in at 1037g/334g, the above at 1052g/328g.
At those weights, the AR1 frame sets seems like the clear bang for the buck.
PostPosted: Mon Jun 16, 2014 5:03 pm
Built up my 58 AR FRD frame friday night. Still mucking with fit etc. Put about 75 miles on it saturday, and another 10 sunday tweaking fit. Bike rides very well. Feels faster than my venge. Not quite as cushy as my Tarmac SL3, but way more responsive - feels at least as stiff in the bottom bracket as the venge. Doesn't have the skittishness that my venge seemed to exhibit. Rear end doesn't have the jarring impacts on road cracks/potholes that my venge had.
Weight of the frame (58) was 1100ish. But I didn't pull out the bolts, derailleur hanger, grommits, or the liner that was run to ease cable runs. Sorry - I was in a time crunch to get it up and together for my Saturday morning ride. The bottom bracket shell is a nice piece of machined carbon - Seemed a bit scary to press fit the bottom bracket directly into the frame, but it worked just fine. Fit/finish on the frame is excellent. Carbon spacers, headset, bearings all worked as expected. I suppose I should have weighed them to compare to the non-FRD versions. There wasn't enough room for a cadence magnet for the SRM on the outside of the bottom bracket shell, so I glued it from the inside through the little di2 hole. Looks/works perfectly. Seatpost clamp is a cool piece of engineering. It clamps down vertically while tightening it horizontally - clamped my 7x9 rails just fine.
Seatpost was 248g, including the bracket that functions as a collar, and the di2 hanger. Fork was 334g uncut. Cut down to 309g with 15mm of spacers. I'm running 5mm above the stem still - might end up 5mm either way for final fit.
Bike build:
ultegra di2 w/ sprint shifters (fd is dura ace, because I couldn't get the ultegra one quick enough),
Specialized s-works crankset with an SRM spider / praxis 39/53 rings
KMC X11 Chain (not an SL)
SRAM XG-1190 11-26 cassette
november rail 52mm wheels
running normal shimano brake cables,
planet-x CNC front brake,
ultegra direct mount rear brake BR-6810,
3t ergonova pro bars 42cm (on my list to upgrade)
Lizard skins dsp 3.2 tape
3T arx II team stem (110mm)
Fizik Antares 00 saddle
Pd-9000 pedals
Specialized rib cage carbon knock off ebay cages
Barfly 2.0
7.11kg.
I'm planning on replacing the bar / cables pretty shortly, which should drop it under 7kg. Beyond that, the $/g ratio of my build gets prohibitive ;) I'll also be replacing some bolts / other miscellaneous stuff with red anodized bits: I've got a k-edge chain catcher on order.
PostPosted: Mon Jun 16, 2014 6:06 pm
It is a little disappointing to see the AR FRD frames coming in at ~10-12% over weight. It helps make my decision of AR FRD vs AR1 a bit easier. Plus saving $1620 (with tax) for something else is nice too. Especially since the weights of the two framesets are much closer in weight than the claimed 150g. Looks to be more in the 75-100g range difference if even that.
There are no new unread posts for this topic. 2014 EVO and 2014 Madone 5.9 frame and brake weight
BLD25
Thu Jan 19, 2017 1:08 am
BLD25 View the latest post
There are no new unread posts for this topic. Felt
Thenuge
14
1488
Fri Aug 11, 2017 5:33 pm
Renne View the latest post
There are no new unread posts for this topic. Tarmac Pro SL4 2014
tarmacdz
Sun Jun 11, 2017 6:54 pm
tarmacdz View the latest post
There are no new unread posts for this topic. Domane 2.3 2014
kordis1
Mon Oct 30, 2017 10:38 pm
FIJIGabe View the latest post
There are no new unread posts for this topic. Felt ar bolt questions!
FredrikE
Fri Apr 14, 2017 8:10 pm
FredrikE View the latest post
Users browsing this forum: Google Adsense [Bot], JScycle, Marin, parker0320 and 38 guests
