It is currently Tue Jan 16, 2018 12:54 pm
Post new topic  Reply to topic  [ 1296 posts ]  Go to page Previous 125 26 27 28 2987 Next
 Post subject: Re: Felt 2014 AR1
PostPosted: Mon Jan 20, 2014 2:21 pm
I got to "visit" my build at the LBS to get some measurements off my Tarmac on Saturday. Looks sweet with the Enves. Picking it up Tuesday but the weather here is crap for at least another 10 days :( Still haven't decided on a saddle but leaning toward the Fisik Kurve or the Prologo Zero II CPC Nack.
PostPosted: Tue Jan 21, 2014 2:09 pm
Nosuga wrote:
No quick release. My wheels are 26.2mm at the brake track. 23 mm tires. So no need to run a quick release.
My Enves don't need a QR, but I have some training wheels (alloys with powertap) and it's looking like the Shimano direct mounts are doing to make changing wheelsets a real pain. Would be nice to fit a QR and a barrel somewhere en route to that brake.
PostPosted: Tue Jan 21, 2014 5:35 pm
Is it any easier to fit the training wheels with the air out of them? I'll be swapping between Reynolds Attack tubular and Mavic Cosmic Elite and would love to get away with just a barrel adjuster. That shimano QR is really ugly and bulky. I did consider fitting the qr under the bb to get it out of the way, but not sure how it would cope with wet conditions down there.
PostPosted: Tue Jan 21, 2014 5:37 pm
Where would you put the barrel?
PostPosted: Tue Jan 21, 2014 6:04 pm
You put an inline QR on the line into the rear brake. I believe it's shimano cb-90. It opens up and also is a barrel adjuster. Pretty nice cuz I can adjust mid ride because it is in my cockpit. Image
PostPosted: Tue Jan 21, 2014 6:11 pm
Thanks Twinning. I've got one of those on order. There's no barrel on it though, is there? I think for adjustment you have just the cable pull and then a single-side adjustment, right?
PostPosted: Tue Jan 21, 2014 6:23 pm
The QR is also a barrel adjuster. It can be spun to tighten or loosen the brake. There is an adjustment on my 9000 direct mount brake that moves the brake if it is off center
PostPosted: Tue Jan 21, 2014 6:27 pm
Whew. Good news. Bad news it he bike shop says the QR won't be in until Thursday. Then again we're looking at sub-freezing temps and snow until at least Sunday so not that much of a loss. I don't think the AR1 will give me any advantage on my rollers. :)
PostPosted: Tue Jan 21, 2014 6:32 pm
Your shop should also put a barrel adjuster somewhere before the cable goes into the frame for the front derailleur. I assume any knowledgeable mechanic will do that
PostPosted: Tue Jan 21, 2014 6:49 pm
Thanks for the pic Twinning. That's why I thought about putting the QR under the BB, I'm sure it wouldn't make much real world difference but the QR there doesn't look very aero to me. A barrel adjuster, to my mind, would be much neater.
PostPosted: Tue Jan 21, 2014 7:01 pm
Nosuga, what barrel adjuster is it you have in line for the rear brake?
With all this talk of QR's I suddenly thought to myself that barrels are usually designed for gear cables so I'd better check the SRAM barrels I bought would fit the thicker width of the brake cables. Turns out they don't! Doh! Looks like I might need the QR after all.
PostPosted: Tue Jan 21, 2014 7:32 pm
I guess you could put the QR near the BB but that would probably disrupt airflow just as much as it would at the top. I haven't tested it out in an air tunnel but I'm sure it won't be the difference between first place and second place in a race.
PostPosted: Tue Jan 21, 2014 8:23 pm
Yeah I know it wouldn't make too much difference in terms of actual drag, but it seems a shame to put such an item that hangs out in the airflow on such a dedicated aero bike. Plus I don't care much for the design of it.
PostPosted: Tue Jan 21, 2014 8:36 pm
All that hard work on the frame and the quick release may as well be a parachute for slowing the bike down!!
PostPosted: Tue Jan 21, 2014 9:24 pm
Having mechanical cabling coming out of the bike already is less aero than electronic. What's one extra QR going to do?
There are no new unread posts for this topic. 2014 EVO and 2014 Madone 5.9 frame and brake weight
BLD25
Thu Jan 19, 2017 1:08 am
BLD25 View the latest post
There are no new unread posts for this topic. Felt
Thenuge
14
1609
Fri Aug 11, 2017 5:33 pm
Renne View the latest post
There are no new unread posts for this topic. Domane 2.3 2014
kordis1
Mon Oct 30, 2017 10:38 pm
FIJIGabe View the latest post
There are no new unread posts for this topic. Tarmac Pro SL4 2014
tarmacdz
Sun Jun 11, 2017 6:54 pm
tarmacdz View the latest post
There are no new unread posts for this topic. Felt ar bolt questions!
FredrikE
Fri Apr 14, 2017 8:10 pm
FredrikE View the latest post
Users browsing this forum: alcatraz, Baidu [Spider], Broady, bruno2000, Conza, liam7020, TurboKoo and 32 guests
cron
