Felt 2014 AR1
AndreLM
by AndreLM
Well… my mistake!
I thought that Felt was using "Direct mount design to match to aero road frames with two-post brake mounts"… like this one: http://www.glorycycles.com/shdu90dimobr.html
But after Bridgey comment, I checked Felt website and indeed, the FRONT brake is clearly a "regular" dual pivot caliper. I am not sure about the REAR brake… from the description of the entire range, apparently the rear brake also uses a standard caliper.
austke
by austke
Yes I was wondering the same thing. But what is meant by "direct mount"?
My understanding of direct mount brakes is that they sit flush against the frame/fork. Eg. Not gap/airflow. Don't stick out as much. :)
2013 Giant TCR Advanced SL 0, 6.92kg
2013 Giant Defy Composite 2 M, 8.5kg - Wife's
Azzurro Torino 8.55g
Fuji 650 10.8kg
Miele Lupa Triple Tandem 38,89kg
mitchgixer6
by mitchgixer6
Guys, this is the type of rear brake (Ultegra 6810) you'll need for the new AR. There are also Dura Ace + 105 variants available. It is indeed the 'direct mount' variant. If you read the whole thread you'll find the answers you're looking for from Dave.
The front brake is indeed a standard mount, Felt did have a special caliper on there for the wind tunnel testing which I think was pulled from one of their TT bikes, and that was indeed a centre pull model. Don't think there's any info about availability for that yet.
trilocus
by trilocus
any news about availability of frames and bikes in europe?
mitchgixer6
by mitchgixer6
I was in at my dealership today, he told me he's been advised to order up any complete bikes he might want for the shop soon as most of them have been selling really fast. I've ordered an AR1 frameset and have been advised late January early February for delivery. I'm in the UK.
LoggingMiles
by LoggingMiles
Anyone know if the AR or F series will work with a Stages Power Meter or is the rear brake clearance too close? Typically those direct mounted breaks under the bb/chainstay do not allow the crank arm with the stages to rotate.
If it does not fit, does anyone know if you can get one of the Felt Aero TT Brakes from any vendor?
Twinning
by Twinning
LoggingMiles wrote:Anyone know if the AR or F series will work with a Stages Power Meter or is the rear brake clearance too close? Typically those direct mounted breaks under the bb/chainstay do not allow the crank arm with the stages to rotate.
It looks like the Felt Aero TT brake will actually be even larger since it is inside a housing which takes up space. You can always switch to a Quarq or SRM! :thumbup:
Zigmeister
by Zigmeister
Exactly, $200+ for the direct mount brake, and 150g weight...not so great.
LoggingMiles
by LoggingMiles
I could, but I already have the Stages...Anyone know of a compatible brake?
LoggingMiles
by LoggingMiles
itsacarr wrote:The Tektro T740 a brake that allows the Stages PM to work.
http://www.tektro.com/_english/01_produ ... rt=1&fid=2" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;
Thanks. And that should be compatible with Ultegra 6870 and the Felt AR mount?
EDIT: Looks like it is OEM only. Not sure if you can find a source for them.
AndreLM
by AndreLM
SuperDave,
I saw you mentioning in Slowtwitch that the new AR is compatible with Campy v2 battery (at least the bigger sizes).
How about the F FRD? Can the seat tube fit the battery? And how about the charging port? Does it have the proper hole under the bb area as well?
(that would be for a size 56, btw)
Thanks!
Andre
Zigmeister
by Zigmeister
Dave answered this on another forum the brake models as well:
"Shimano Dura-Ace, Ultegra, 105, TRP T750 and T740 as well as EEcycleworks have rear brakes that fit the Shimano direct-mount standard."
LoggingMiles
by LoggingMiles
Great. Thanks.
I will see if I can find a source for the TRP OEM brakes. I do not believe any of the Shimano variants will have the required clearance.
Mize
by Mize
Those EEcycleworks sure are slick...for 10x the price :(
