It is currently Thu Jan 19, 2017 3:56 am
Post new topic  Reply to topic  [ 1296 posts ]  Go to page Previous 114 15 16 17 1887 Next
 Post subject: Re: Felt 2014 AR1
PostPosted: Fri Oct 11, 2013 7:37 am
When will the FRD AR frameset be available in Europe?
2015 S-works Tarmac DA9000, 6,29kg
PostPosted: Fri Oct 11, 2013 8:59 am
January.
-SD
http://www.3Tcycling.com
https://www.strava.com/athletes/164090
PostPosted: Sat Oct 12, 2013 6:44 pm
Hi Dave
A few more questions from me if you don't mind?
Firstly a techie one. Will the 3T vibration reducing clamp be available on all frames, and is it an extra cost option?
Secondly on vanity! I'm wondering if the graphics on the seat tube spell a word out or are they just squiggly lines? I must admit I like the plain look of the test bike shot in the wind tunnel.
Many thanks.
PostPosted: Sat Oct 12, 2013 8:08 pm
Ba!
PostPosted: Tue Oct 15, 2013 1:51 am
mitchgixer6 wrote:
Hi Dave
Many thanks.
Yes, the 3T equipped Vibration Reducing seatpost (VR) will be available as a replacement for the VM design that comes with the AR FRD, AR4 and AR5.
The AR FRD uses a special TeXtreme lay up on the seatpost which makes it a bit lighter than the posts used on the other models. The VR comfort module adds about 25g to the seatpost weight.
-SD
PostPosted: Tue Oct 29, 2013 3:58 am
Hi Dave,
I red this topic with great attention. I'm a 39 years old racer with more than 20 years of racing and was looking at those aero bikes for the next season. At first, I was looking at the Propel but the brakes issues mentioned in few reviews made me think again. Here in Quebec, we do alot of criterium so brakes are important. Also, our road races are on flat, windy condition so the AR should be a good option. I'm also thinking about using this bike for a few TT and triathlon with clip-on.
Now my questions, I'm 5'7", and at 175 pounds, I consider myself as a "muscular" rider and need a frame that can hold quick acceleration. I'm from a Giant TCR ADV SL and this frame was awesome. Is the AR4 stiff enough? I'm quite confused with all the carbon levels in the FELT lineup but one thing is shure, I need a stiff frame for criteriums. I took a look at the AR2, the carbon seemed better but I don't really wan't DI2 and don't like the wheels so for the price, is the frame that good to make me want the AR2?
Now for the sizing. My BB-top of saddle measure is 70.6cm. I'm always between a small and a medium. The headtube and top tube seem a bit short on the small but with my size, would the medium seatpost to short?
Thanks and please excuse my average english.
PostPosted: Wed Oct 30, 2013 1:37 am
emartin wrote:
Hi Dave,
The AR models are made with the same BB stiffness as our F-series models which share the same stiffness for production bikes as the frames we supplied to Garmin and now to Argos. You can find a few resources online from Roadbike, Tour, ProCycling and others that rate the F-series BB stiffness among the highest available period. From a stiffness to weight perspective, only the Cannondale Black Supersix EVO and Cervelo R5CA (and now RCA is claimed) are as good as the F-series.
If you don't want Di2, the AR3 R or AR1 frameset would be a good choice. If you plan on TT events as a dual use bike I'd recommend the 51cm size. A 54cm would give you a huge head tube to deal with on a TT bike.
-SD
PostPosted: Wed Oct 30, 2013 1:55 am
-SD
Thanks for the reply,
Instead of the AR2, the AR4 is the bike that would give me the best options with mech Ultegra. If I understand correcly, this frame would be as stiff as what I'm used to, am I right?
As for frame sizing, compare to Giant, your medium frame for exemple have a much shorter headtube an toptube. Since I'm used to Giant geometry, this is where I have some reserve. How come a 140 mm headtube would be massive vs Giant 150mm? Please highlight me.
Regards
PostPosted: Wed Oct 30, 2013 5:15 pm
-SD
Regards
The AR4 would be just as stiff as the AR2 but not as light.
I wouldn't characterize 10mm as a "massive" difference. Just ad a 10mm headset spacer, or a shallower drop or a different bend so the hoods are positioned higher or a different stem stack or a flat top handlebar, or a 35mm handlebar or a myriad of other solutions to increasing bar height. It is also possible that you'll find the bar position to your liking. As you are used to Giant geometry, I trust you'll eventually get used to AR geometry.
I had the opposite problem going from a Felt F-series frame to the new AR. I started by using a -17 degree stem but eventually have settled on a -10 degree stem, slightly wider bars, and a slightly lower hood position on the PRO bend. After a few weeks it feels and fits great.
10mm of bar height is about a 2 degree difference in elbow bend.
-SD
PostPosted: Wed Oct 30, 2013 9:32 pm
SuperDave wrote:
-SD
Regards
-SD
Thanks again for the reply,
Because the bike with be mainly use on crit and road race, I choose a AR2 medium, my friend (who is also my LBS) convainced me about DI2 and the 3T wheelset, I placed my order today! I also prefer to put the stem all the way down with no spacer and after 20 years of racing...I'm not as flexible as I used to.
PostPosted: Thu Oct 31, 2013 12:31 pm
Hi Dave.
Are you able to pull any strings to get a frame to the UK for me?! :-)
Dealer is stating early new year but no confirmed month. Would LOVE to have the AR ready for my traditional first race of the year (2 up TT) mid February.
PostPosted: Thu Oct 31, 2013 4:05 pm
mitchgixer6 wrote:
Hi Dave.
Ok. Can you provide any additional information?
-SD
PostPosted: Thu Oct 31, 2013 11:33 pm
I'm just about to head to bed, been a long Halloween night here! Not figured out hot to send PM's on here from my phone, will send you one in the morning Dave. Thanks for the help! :-)
PostPosted: Fri Nov 01, 2013 8:53 am
Hi SuperDave i want to know the tyre clearance in felt ar frd frameset, can fit. 700x25 tubulars? Shimano internal battery can be used in the seatpost?
Thank you
Enviado desde mi C6833 mediante Tapatalk
PostPosted: Fri Nov 01, 2013 10:38 am
I asked him the same question before and he said 25 mm tires are no problem.
My Bikes
My Photoblog
There are no new unread posts for this topic. Campagnolo SR/Record/Chorus 2014 shifters & pre-2014 crankset: experiences?
neeb
18
1643
Mon Jul 11, 2016 1:03 am
neeb View the latest post
There are no new unread posts for this topic. 2014 EVO and 2014 Madone 5.9 frame and brake weight
BLD25
Thu Jan 19, 2017 1:08 am
BLD25 View the latest post
There are no new unread posts for this topic. FELT FR FRD
newforker
39
4049
Wed Oct 19, 2016 4:01 pm
wheelzqc View the latest post
There are no new unread posts for this topic. 2014 TCR ADV SL vs. 2016 TCR ADV Pro frame value...
diegogarcia
9
1001
Sun Sep 18, 2016 7:31 pm
diegogarcia View the latest post
There are no new unread posts for this topic. 2014 Cervelo R5 Paint
erickpauljohnson
Fri Oct 14, 2016 10:10 pm
erickpauljohnson View the latest post
Users browsing this forum: Bing [Bot], ewwhite, Google Adsense [Bot], ihs0yz, madonna and 18 guests
