It is currently Thu Jan 18, 2018 9:13 am
Post new topic  Reply to topic  [ 1296 posts ]  Go to page Previous 111 12 13 14 1587 Next
 Post subject: Re: Felt 2014 AR1
PostPosted: Thu Aug 29, 2013 12:40 am
Without them actually listing trail there is a few other factors which could be at play such as Axle to Crown length.
Personally I want to thank Felt on the behalf of short people for making an effort with small bike geometry (like they have been for a while) rather than just slapping a slacker head angle and steeper seat angle on there and calling it done.
PostPosted: Thu Aug 29, 2013 4:31 am
Ax-Cr is 370 so nothing funky happening there. I agree about great to see the effort on the small bikes as the old AR was quite long reach. But also agree about not liking 51mm of trail on the big frames - it would be nice with a 40mm fork. Do feel a bit let down that they have 4 different fork rakes in the range (which is about 4x as many as most brands...) but they couldn't do one more (or slacken HTA).
http://www.speedtheory.co.nz
http://www.velogicfit.com - 3D Motion Capture and Frame Finder Software
PostPosted: Thu Aug 29, 2013 7:43 am
So.....the Felt FRD frameset can not be run with mechanical or hydraulic?? only electronic?!
PostPosted: Thu Aug 29, 2013 7:48 am
That's correct - The AR FRD is electronic only, where as the mechanical version is the AR1 - which I think is is awesome value, considering it's only like $2500 for the frames.
KWalker wrote:
chill out perv dogs, homegirl is still only 17.
PostPosted: Thu Aug 29, 2013 4:54 pm
JBV wrote:
74' head angle in the two upper sizes results in very unstable handling at higher speeds, in my experience. I had a 60cm F1 some years ago with that same combo, I swapped in a 40mm rake fork and it was rideable, but 43mm and 74' results in too little trail. Fine for turning under ~25mph, but very hard to rail a corner at racing speeds, or descend mountains with switchbacks.
I'm an upper category racer with >25 years experience, BTW.
Would love to hear Felt's rationale for this, as otherwise these are fantastic bikes. SuperDave?
Weird, most of the higher end custom builders use that HTA and rake and do just fine. I ride a 58 and am going with that with my custom build and its been perfectly stable on other bikes I've ridden.
Gramz
Failed Custom Bike
PostPosted: Thu Aug 29, 2013 7:28 pm
Interesting, I've ridden two bikes with 74' HTA, both were only raceable with 40mm rake. 43 was tough to deal with, 45 was nearly impossible. Maybe just what I'm used to?
PostPosted: Thu Aug 29, 2013 9:15 pm
"Some years ago" were you using 19 mm tires? These reduce trail relative to 23-25 mm tires.
http://djconnel.blogspot.com/
Fuji SL/1
PostPosted: Sat Aug 31, 2013 2:29 pm
SuperDave,
why is the listed felt AR FRD frameset so heavy ?
Weight:
1.77kg, 3.9lb
http://www.feltbicycles.com/USA/2014/Bikes/Road/AR-Series/ar-frd-frameset.aspx
Current Rides:
2017 Giant TCR Advanced SL 0 DI2 9150
PostPosted: Sat Aug 31, 2013 5:07 pm
Just guessing, but it may include the seatpost
PostPosted: Sat Aug 31, 2013 7:46 pm
My guess is it includes everything listed. Frame, Fork, Seatpost with binder, BB, Headset, hanger. Nice!
PostPosted: Sun Sep 01, 2013 8:22 pm
Sykes wrote:
I am curious as to one thing, both in the TDF and more recently the Pro Challenge, why A/S team isn't using the AR more? Even on sprinter stages the guys use the F over AR. I have no reason to doubt SuperDave's info, and I'm sure there is a good reason, but I keep asking myself why the pros don't use the AR. This is especially curious because everything we have been told about the AR says that it has bridged the compromise between aero and traditional road frames.
This isn't just an A/S team choice though, I did not see any S5s on the Pro Challenge, but since we have Dave's ear maybe he could enlighten us.
The Argos guys are racing on F-series bikes because that is what we provided this sprinter-focused team. Almost all the riders are using the low aggressive F-series bikes with PRO -10 degree stems with no or a 5mm headset spacer. A few guys are on -17 degree custom stems on an F-series bike. As the highest STW of any other bike we offer, the F FRD was the perfect choice.
The new AR bicycles haven't begun mass production in the AR FRD format just yet, delivering all new bicycles above and beyond the contractual obligations in September doesn't seem like a wise investment. With a few dozen wins including bookending the Tour de France with victories over Cav, the gorilla, and Sagan, I think their equipment choice is far from limiting.
-SD
http://www.3Tcycling.com
https://www.strava.com/athletes/164090
PostPosted: Sun Sep 01, 2013 8:28 pm
hasbeen wrote:
Disappointed that the geo isnt more like the F series. Those headtube heights are silly.
Silly? The new AR is equipped with a special two-piece headset cover that offers a 4mm or 20mm cone spacer. The F-series bikes come with a standard FSA 15mm cone spacer. With the lower 4mm spacer on an AR and a -17 stem available from dozens of stem makers, the AR can be set up lower and with less frontal area and reduced drag. By designing the frame that offers the wind more of the aerodynamically shaped head tube and less of the round F-series ControlTaper head tube, headset stack and steerer tube spacers we can provide a faster bike.
If you are among the 0.4% of the consumer population riding the F-series bike with a low-stack headset and a -17 degree stem without spacers now then yes, the AR is not for you, but I'd argue that in that specific case your position is silly, not our bike.
The other positional dimensions on the F and AR series bicycles are now the same with the exception of a couple mm in the chainstay length.
-SD
PostPosted: Sun Sep 01, 2013 8:53 pm
Dave any confirmation that the ARA will be sold as a frameset only in Europe and not just as the AR15?
"Step forward the climber and all those who worship at the altar of lightness" - R. Millar
PostPosted: Sun Sep 01, 2013 8:55 pm
I'd love to hear your feedback on the bike after riding a 2014 version vs the ~2007 thru 2009 F1. The new bikes are 50% stiffer in the head tube resulting in far more steering precision. The bigger guys we've had racing our 61cm size had a great deal of input on the steering geometry used. Guys like Maggie selected the 43mm offset after trying a variety of different fork offsets. Early on with Slipstream you can see him on Oval and 3T front ends playing with the fork rake finding the balance he desired. Now big guys like Stamsnijder find the agile handling a perfect match for the longer wheelbase of the larger bikes.
I agree the quick handling must be a feature desired for the pilot for the geo to work but that is why we offer various models in the road line. The Z series bikes for example.
-SD
PostPosted: Sun Sep 01, 2013 9:23 pm
It should work with hydraulic if the technical information is ever finalized for those groups.
https://sphotos-b-sjc.xx.fbcdn.net/hphotos-ash4/r90/1236600_10201917632608435_1213258874_n.jpg
It will not work with mechanical as there are no additional patches in the carbon lay up where the cable stops or guides would pierce the frame to reduce the weight of the bicycle as much as possible.
The ~1000g AR1 can be set up with mechanical shifting and is comparable in weight to the lightest aero road frames on the market today. If you prefer mechanical shifting, there are options in the AR line.
There are no new unread posts for this topic. Felt
Thenuge
14
1612
Fri Aug 11, 2017 5:33 pm
Renne View the latest post
There are no new unread posts for this topic. Domane 2.3 2014
kordis1
Mon Oct 30, 2017 10:38 pm
FIJIGabe View the latest post
There are no new unread posts for this topic. Tarmac Pro SL4 2014
tarmacdz
Sun Jun 11, 2017 6:54 pm
tarmacdz View the latest post
There are no new unread posts for this topic. Felt ar bolt questions!
FredrikE
Fri Apr 14, 2017 8:10 pm
FredrikE View the latest post
There are no new unread posts for this topic. 2014 Addict Team Edition HMX
jzinckgra
9
709
Sun Nov 19, 2017 1:23 am
jzinckgra View the latest post
Users browsing this forum: Bing [Bot], Discodan, dualathlonpc, Google Adsense [Bot], nlop, sike1000, Zakalwe and 16 guests
