[phpBB Debug] PHP Warning: in file [ROOT]/viewtopic.php on line 1612: memcache_connect() [function.memcache-connect]: Can't connect to localhost:11211, Connection timed out (110)
[phpBB Debug] PHP Warning: in file [ROOT]/viewtopic.php on line 2201: memcache_get() expects parameter 1 to be Memcache, boolean given
[phpBB Debug] PHP Warning: in file [ROOT]/viewtopic.php on line 2202: memcache_get() expects parameter 1 to be Memcache, boolean given
[phpBB Debug] PHP Warning: in file [ROOT]/viewtopic.php on line 2203: memcache_get() expects parameter 1 to be Memcache, boolean given
[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 5445: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3925)
Felt 2014 AR1 - Page 8 - Weight Weenies
It is currently Mon Feb 20, 2017 4:55 am
Post new topic  Reply to topic  [ 1296 posts ]  Go to page Previous 16 7 8 9 1087 Next
 Post subject: Re: Felt 2014 AR1
PostPosted: Wed Aug 21, 2013 8:43 am
Cheers! wrote:
This is the first time under the new regime. Previous 5 bike purchases were made before any wife and it was usually during a time of no significant other...
Just get the new bike in same color than the old one. ;)
And of course keep the total count of the bikes same in case if she goes and counts them....
PostPosted: Wed Aug 21, 2013 3:07 pm
It looks nice!
I only have two questions:
1. Will the framesets (either the electronic version or the mechanical) be able to accommodate hydraulic shifting? Or is the owner obligated to buy a new frame when those systems soon come out?
2. Have the geometry tables been posted anywhere?
PostPosted: Wed Aug 21, 2013 4:39 pm
Is there a super hi res image of the AR FRD I can use as my desktop wallpaper?
http://www.hackracer.com/
Good point: both hydraulic braking and shifting.
There are two shifting systems in the pipeline for road. One of them is coming from Acros, the other is coming from a substantially larger company.
Funny, the "aren't many" could have been said for electronic a few years ago before Shimano released Di2... now look where we are. :mrgreen:
PostPosted: Wed Aug 21, 2013 4:45 pm
"the other is coming from a substantially larger company."
It is ok Prend you can say SRAM on here. I don't think that is any secret.
PostPosted: Wed Aug 21, 2013 4:48 pm
With their move into hydraulic braking it is only natural to move into full hydraulic systems.
EDIT: This could mean some very cool designs in bikes because you could move away from what we know as standard brake and shifter cables.
BIG DADDY B FLOW
AERO & LIGHT is RIGHT
Cervelo SLC 5960g/13.13 lbs
PostPosted: Wed Aug 21, 2013 5:06 pm
53x12 wrote:
SD, similar to the F1 vs FC, will the AR FRD have a carbon bb shell and the AR1 and others have an alloy one?
Yes. AR FRD uses a unique carbon shell whereas the AR1 uses the textbook CNC machined aluminum sleeve that requires C-clips to retain the bearing spacing.
-SD
http://www.3Tcycling.com
https://www.strava.com/athletes/164090
PostPosted: Wed Aug 21, 2013 5:15 pm
tranzformer wrote:
Any idea what the weight is of the rear Felt brake with all the hardware and associated bits?
160g for the brake, 175g with all the mounting bits and guide pipe, add another 4g if you run an inline adjuster to compensate for rim width changes.
-SD
PostPosted: Wed Aug 21, 2013 5:19 pm
MarkGiardini wrote:
Hi Dave.
Is the rear brake a proprietary style job, or can anything be used?
With regards to the AR FRD v the AR1, I assume if you want to keep mechanical groupset then that rules out the FRD correct?
Mark
The rear brake uses the Shimano rear direct mount standard.
Shimano Dura-Ace 9010R, Ultegra 6810R, 105 5710R, TRP T750, TRP T740, and Bontrager's rear brake off the new Madone will fit. There are more coming including adaptors so hydro brakes like Magura and SRAM can be used as well on the same mount.
-SD
PostPosted: Wed Aug 21, 2013 5:25 pm
JN2Wheels wrote:
SuperDave wrote:
The AR4 and AR2 frame, fork, and seatpost are indeed different in terms of lay up and frame molds.
I'm crystal clear on where the OEM price differences are of these components and why there is a $2500 price jump from the AR2 to the AR4 but perhaps there are aftermarket sources that dip well below the MSRP.
I can add on the cost differences on the frameset and the penalty that the small volume of Di2 production adds vs. the huge volume of mechanical Ultegra bikes but I think you'll find these differences are absorbed and the component price differences are higher than you anticipated.
-Dave
Thanks for details, SuperD! My question may have come off a bit abrasive. I was just floored to see an Ultegra DI2 build at such a price point, and $2700 dollars more than the mechanical equivalent. I mainly wanted to clarify it wasn't a typo! I'm sure you have the numbers. And thanks for sharing the spec bump specifics.
Knowing that the layup is different for both frame and seatpost does explain a little. It's just that for most people, UDi2 is the way in to electronic at a budget-friendly price point. For me, at least, I feel you guys may have missed the point by upspeccing that model so much. Let 9070 stand as the premium shimano electric, and use Udi2 to entice new electronic customers who are price sensitive.
Anyway, the frame looks awesome and will no doubt do very well. Congrats, and I can't wait to read first rides!
Help me with your expectations please.
Start with the Felt AR1 frame (or any companies carbon aero road frame)
Add an Ultegra Di2 11 speed group
Add 3T carbon cockpit and 3T carbon wheels
Add any premium ti-rail saddle
Add any premium clincher tire
What do you expect to pay for the bike describe above? Just like grade school, show your math work.
It is also worth noting that Ultegra Di2 won't show up in any significant quantity before Jan 1st cutting potential sales volume (for us) in half.
-SD
PostPosted: Wed Aug 21, 2013 5:26 pm
Cheers! wrote:
I want a AR FRD so bad. How do I convince the wife?
Buy two.
-SD
PostPosted: Wed Aug 21, 2013 5:30 pm
prendrefeu wrote:
It looks nice!
Hydro shifters? If you are referring to the SRAM images leaked, those were a joke. If you are referring to the ACROS(?) system shown at Eurobike a couple seasons ago, then yes, their hydro shift housing would fit through our mechanically routed internal holes on the downtube of the AR1, AR3R, AR4, and AR5. You'd need the hydro cable guides off the Z2R or Z3R model. I have no idea how to detach and/or bleed that system though.
Geo will be published with the web launch to coincide with EB. If I were better at cut and pasting from excel into this BB I'd drop them in here but I trust you can wait a week.
-SD
PostPosted: Wed Aug 21, 2013 5:32 pm
Yes, we have a huge file I could send you in .eps format or you can download it from our website in .png or .jpg once it goes live next week.
-SD
PostPosted: Wed Aug 21, 2013 6:03 pm
Ummm... no, not the "leaked images" - those we determined to be fake long ago.
ACROS is developing a Road shift system, as verified at Interbike 2012 and from insider contacts is very close to release.
... and then, finally, word from your competition: viewtopic.php?f=3&t=113669&start=90#p996220
As you know, WW aren't fools to fall for the fake images that float around the internet!
That said, the reason I asked is because some of us choose to keep a frame or components for several years and upgrading selectively rather than buying new things all the time. Well, some of us. I like this frame, and potentially if the geometry works, it is worth consideration - but I want to know if it will accommodate the near future. :wink:
The new AR series has two separate and distinct frames: one designed for eletronic, the other for mechanical.
On the other side, the newest Cervelo RCA has one frame that can take on all three drivetrain & shift options, with a simple switch of some small grommets.
Thanks!
PostPosted: Wed Aug 21, 2013 6:06 pm
-SD
Cool. Look forward to a new background.
There are no new unread posts for this topic. Campagnolo SR/Record/Chorus 2014 shifters & pre-2014 crankset: experiences?
neeb
18
1723
Mon Jul 11, 2016 1:03 am
neeb View the latest post
There are no new unread posts for this topic. 2014 EVO and 2014 Madone 5.9 frame and brake weight
BLD25
Thu Jan 19, 2017 1:08 am
BLD25 View the latest post
There are no new unread posts for this topic. FELT FR FRD
newforker
39
4189
Wed Oct 19, 2016 4:01 pm
wheelzqc View the latest post
There are no new unread posts for this topic. 2014 TCR ADV SL vs. 2016 TCR ADV Pro frame value...
diegogarcia
9
1061
Sun Sep 18, 2016 7:31 pm
diegogarcia View the latest post
There are no new unread posts for this topic. 2014 Cervelo R5 Paint
erickpauljohnson
Fri Oct 14, 2016 10:10 pm
erickpauljohnson View the latest post
Users browsing this forum: Baidu [Spider], Google Adsense [Bot], kevosinn, leej88, Yahoo [Bot] and 34 guests
