It is currently Sat Jan 21, 2017 8:09 am
Post new topic  Reply to topic  [ 3 posts ]
 Post subject: Pulley wheel size
PostPosted: Fri Aug 16, 2013 7:15 am
I'm looking to replace my pulley wheels on my shimano rear der. I'm thinking about some light weight ceramic wheels. But as im looking to replace them another question pops up. On friction facts i read that the bigger the size the lower the friction. So if I was to replace them why not get a bigger size? Does anyone have experience with bigger size wheels? What's the max size? And are upper and lower wheel the same size or could you go for a 11/ 13 size, and if so is it better to have a bigger lower or upper wheel ?
Loads of questions. Looking for some help.
Everything is all right in the end, so if everything is not allright it's not the end
PostPosted: Fri Aug 16, 2013 1:03 pm
Would you not struggle to fit the wheels in without removing the little tabs that the chain is supposed to fit through, one on the bottom of the derailleur and the other between the 2 pulleys? With those still in place there would be no room for bigger wheels. Personally don't know if it would even work after that but, see that as your first issue at least.
 Post subject: Re: Pulley wheel size
PostPosted: Fri Aug 16, 2013 1:16 pm
You can buy them here, http://83.169.41.216/drupalprod/catalog/11
http://www.gs-carbonparts.com/produkte.html
Plenty of info on here too viewtopic.php?f=3&t=36580
There are no new unread posts for this topic. World fastest and lightest oversized pulley wheel cage system
Stirling
38
4208
Wed Jan 18, 2017 1:22 pm
mrgray View the latest post
There are no new unread posts for this topic. Oversized Pulley Wheels for SUPER RECORD EPS V3
leej88
Wed Oct 12, 2016 4:42 pm
Hexsense View the latest post
There are no new unread posts for this topic. 2015 Super Record Lower Pulley Issues
davidw
Mon Oct 10, 2016 6:03 am
davidw View the latest post
There are no new unread posts for this topic. BMC seat clamp size
Serrom
Tue Oct 04, 2016 9:41 am
pressed001 View the latest post
There are no new unread posts for this topic. Chainring size efficiency
alcatraz
12
1284
Tue Oct 11, 2016 12:59 pm
Marin View the latest post
Users browsing this forum: Arrgo1, MSNbot Media and 23 guests
