It is currently Wed Jan 17, 2018 7:28 pm
Post new topic  Reply to topic  [ 6 posts ]
PostPosted: Fri Aug 16, 2013 7:12 am
I just wanted to share with the WW forum, another pedal option called the Xpedo Thrust SL Ti spindle.
Here are some stats: Carbon injected moded body. Titanium spindle. Three cartridge bearing. Elastomer spring. Claimed weight of 168g. My came in at 163g/pair. L**k Keo cleat compatible. Comes with two pairs of cleats, 6 degrees (red) and fixed (dark gray) float cleats. Also comes with two sets of cleat bolts+washers, and spare bolts. 85kg weight limit.
Personal thoughts: The release tension is fixed, and after a few rides, it feels about the same tension as the Dura Ace PD-9000 pedals set at medium. I purchased these pedals on a whim, while browsing ebay, and the prices are about $220 USD. Not cheap, but acceptable for a WW pedal. Not sure on the durability, but time will tell.
Here are some pictures. Enjoy:
Comes with all this.
*Editted, fixed title from Xedo to Xpedo.
Xpedo Thrust SL pedal weight (162.6g):
6 degree (red) cleat weight (56.9g):
Fixed (dark gray) cleat (56.3g):
Bolts and wasters (24g)
2013 Colnago C59 TSMR
2012 Colnago C59 CSLM
PostPosted: Sat Aug 17, 2013 2:47 am
A long time ago, I owned some elastomer tensioned mountain bike pedals. I loved them until I used them during the winter, and found myself unable to unclip! I guess the elastomers hardened up in the cold.
Do you think these will suffer the same problem?
PostPosted: Sat Aug 17, 2013 4:22 pm
Good point. I have not thought about how the elastomer spring will behave in the cold. When it gets cold here in November or December I will find out if the elastomer will change tension.
PostPosted: Sat Aug 17, 2013 4:30 pm
Cool. Thanks for sharing.
PostPosted: Sat Aug 17, 2013 8:26 pm
Location: Lima, Peru and occasionally in the Washington DC area.
@vinceflynow, how cold does it get in your neck of the woods? I think we need someone in Michigan to test these through the winter, not a Californian! :mrgreen:
PostPosted: Sat Aug 17, 2013 11:06 pm
The coldest it gets where I live in California, is about 9-10 degrees Celcius (50 degrees Fahrenheit) in the middle of January. I do ride in those conditions, and will update my findings early next year. :)
There are no new unread posts for this topic. Look pedal removal - allen key vs pedal wrench?
mvcap
19
1627
Thu Nov 30, 2017 5:32 pm
Rick View the latest post
There are no new unread posts for this topic. Canyon Ultimate CF SLX 2015 model
Timujin
Fri May 19, 2017 11:41 pm
totalcompactroad View the latest post
There are no new unread posts for this topic. Please help with scott foil model year
kelih
Fri Jun 23, 2017 3:11 pm
kelih View the latest post
There are no new unread posts for this topic. Which Model of Helmet Do You Wear and Why? How Frequently Do You Replace It?
[ Go to page: 1 2 3 4 5 6 ]
Squashednuts
80
7473
Tue Sep 12, 2017 3:27 pm
MXGimp View the latest post
There are no new unread posts for this topic. Pedal stack
hlvd
Sat Jul 22, 2017 12:03 pm
hlvd View the latest post
Users browsing this forum: 2focused, bikeguy0, Christono, darnellrm, faucon, huddini, tmr5555 and 37 guests
