It is currently Thu Jan 18, 2018 11:03 am
Post new topic  Reply to topic  [ 4 posts ]
PostPosted: Thu Aug 15, 2013 3:18 pm
Hi all,
Wondered if anyone else had come across this. With some of the cheaper Shimano wheels on the market coming with a fully threaded axle, namely the area that sits on the carbon drop out of the frame, has anyone experienced this digging into the actual inside area of the drop out?
I get the serrated teeth area on the skewer and axle nut digging into the flat clamp sections on the dropouts, this is a common problem, but I mean the inside of the dropout where the threaded axle section rests on.
It has worn the dropout on the drive side to the point where the wheel now can move slightly forward on the drive side, leaving it non centre in frame.
Any ideas or suggested fixes, as this kind of wheel will always dig into the frame?
PostPosted: Thu Aug 15, 2013 3:33 pm
That really sounds like the axle is are missing or has an incorrect end cap if the axle has exposed threads and would ask to which specific model of Shimano wheelset are you referring?
PostPosted: Thu Aug 15, 2013 4:25 pm
I am talking about the RS80 rear wheel. I'm pretty sure that's the way they come standard. Threaded axle so the nuts can be used to set bearing preload, then the same axle area that the nut screws over, doubles up as the end cap section that sits in the dropout.
PostPosted: Thu Aug 15, 2013 4:49 pm
Yeah, this is how they come standard......I have never had an issue with this sine I used the Shimano skewers that held very tight and prevented movement in the dropout. If you use less robust skewers, I can see where some movement could occur that could damage the dropout.
Mosaic RS-1
http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=138478
Cielo by Chris King Cross Racer
http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=134376
There are no new unread posts for this topic. Rear Derailleur Pulley Wheels / Jockey Wheels - 17t and oversized sizes - where?
prendrefeu
27
1965
Wed Jan 03, 2018 3:28 am
morganb View the latest post
There are no new unread posts for this topic. How to drill out the rivets of the Shimano 9070 rear derailleur?
2old4this
14
1772
Tue Feb 07, 2017 4:47 am
2old4this View the latest post
There are no new unread posts for this topic. Upgraded jockey wheels on DA 9100R rear derailleur
tantra
Fri Aug 11, 2017 2:18 am
Pokerface07 View the latest post
There are no new unread posts for this topic. New Wilier has direct mount caliper / disc and swappable dropouts all in the same frameset
jeffy
Wed Jun 28, 2017 7:07 pm
MyM3Coupe View the latest post
There are no new unread posts for this topic. REAR HUB ZIPP 188
nick007
Thu Aug 24, 2017 9:20 am
kavitator View the latest post
Users browsing this forum: karmaz, KKB, lovemyway, PinaF8 and 41 guests
