It is currently Wed Jan 18, 2017 1:53 pm
Post new topic  Reply to topic  [ 5 posts ]
PostPosted: Thu Aug 15, 2013 11:58 am
Hi, just installing some new cantilever brakes to an old 1980s frame I picked up. Upon installing the new cantilever brakes, the right hand side take amount appears to sit higher up than the left hand side - however when I measure the mounting bosses either side they seem to be equally positioned. Also I noticed when the original wheel is in place, it runs centrally, whereas if I replace the front wheel with another wheel I have which is true, it runs slightly to the left - making brake alignment a right pain. My only though is that perhaps the fork is bent?
PostPosted: Thu Aug 15, 2013 12:57 pm
If the fork is bent and you think the previous owner dished the wheel to center it, just turn the wheel around 180 deg and see if it's off center.
Also you can file the dropout slightly if it's not too far out.
PostPosted: Thu Aug 15, 2013 3:03 pm
Heres a snap, see the right brake mount appears slightly higher than the left.
PostPosted: Thu Aug 15, 2013 5:09 pm
In that pic the bosses looks quite a bit out, have you taken the brakes off and checked the studs, do they look parallel to each other?
PostPosted: Thu Aug 15, 2013 8:10 pm
It is off by a few mm either side!
Should this hinder the braking action, as in the pads still touch the rim just on one side they are at their lowest possible, whilst the other side not.
Its also interesting how other wheels do not sit centrally. Something must have given it a decent whack at some point in its life...?
There are no new unread posts for this topic. Attachment(s) ww hanger alignment tool
sungod
25
1846
Fri Jun 24, 2016 3:19 pm
sungod View the latest post
There are no new unread posts for this topic. EE-brakes
bruno2000
25
2418
Thu Jun 23, 2016 2:38 am
2lo8 View the latest post
bruno2000
Fri Jun 17, 2016 5:35 pm
Sim0n0 View the latest post
There are no new unread posts for this topic. Brakes
goldielox
10
863
Sat May 14, 2016 7:11 am
Synnove View the latest post
There are no new unread posts for this topic. Has anyone tried to run EE brakes with CLX 64 wheels?
Imaking20
Sun Nov 20, 2016 1:46 am
Imaking20 View the latest post
Users browsing this forum: Broady, CrankAddictsRich, darnellrm, gewichtweenie, Kumppa, MSNbot Media, nikbergerac, ooo and 27 guests
