Best way to replace rails on Arione saddle?
Svetty
by Svetty
I have a broken (Kium) rail on an otherwise newish saddle. I also have an older ordinary Arione. What is the best way to replace the broken rail with one from the other saddle? Solvents, heat, mechanical force? Thanks
lannes
by lannes
don't think you can do it, without affecting it structurally, you probably just break it somewhere else after you unbond it
Svetty
by Svetty
187 views and only one reply :(
Can't believe that with a modicum of ingenuity and engineering skill this can't be done. Will report back once done it :)
mattr
by mattr
If the rails are not bonded in (some CF saddles have bonded in rails i think?) you *can* stretch/flatten the saddle and bend the rails until they pop out of the location features. You may end up with a permanently bent rail if you go too far. Also, best to work out which of the location features are deepest, and work on the other ones! (less bending to pop it out).
Best method is brute force and swearing (unfortunately).
And a big vice.
Svetty
by Svetty
Was thinking of drilling broken ends of rail out of saddle, and liberating rail from donor saddle by effectively destroying locating sockets. Just need then to locate rail....
Tenlegs
by Tenlegs
From 1:22 you can see (briefly) how the rails are fitted, http://www.youtube.com/watch?v=BTS3v_fEJIk
and here from 4:00 http://www.youtube.com/watch?v=rwCkbcUXCJ8
pyrahna
by pyrahna
Honestly drop a note by Fizik's customer service. Assuming you didn't set out to intentionally break the saddle they will probably cover it. They just warrantied a saddle for me and it was an utterly painless experience.
Svetty
by Svetty
@ pyranha. Could u let me have contact details? I'm in UK btw
Thanks!
ultimobici
by ultimobici
Why not just walk into the store that you purchased it from and ask them if they can send it back to Extra who are the UK distributor?
