Going for larger chainrings - chain length?
by Kermithimself
Currently I'm riding with a 50/34 combination on my Rotor crankset. Would like to have a 52/38 combination instead. If I choose the larger chainrings, do I then need to lengthen the chain, or will it work ok?
If you dream of being famous - think of what birds do to statues.
Instagram: https://www.instagram.com/kermithimself/
Youtube: https://www.youtube.com/channel/UCdCPaXwpeXT_LpuEF0REjqw
Facebook: https://www.facebook.com/gotlegscycling/
by savechief
It depends on how long your chain is now.
Time VXRS Ulteam (7.16 kg)
by Beancouter
You'll most likely need a longer chain. Sure someone will correct me but basic rule of thumb for minimum chain length is to wrap chain around largest cogs front and rear (not Passing through rear changer) and add 2 links.
5 8 5
by 5 8 5
If it was originally fitted using the small / small method (ie longest) you may be okay.
by TrekUk
id be pretty suprised if you didnt have to change your chain for a bigger one.
Madone Five Series 2013
Shimano Dura-Ace 9000
Mavic Cosmic SLE 2013
by bikerjulio
As everyone else has said - it depends on what length your chain is now.
If you put in the big-big combo now and the RD is really stretched out, then you need a new chain. If there is still some slack you are probably OK.
There's sometimes a buggy.
