WW techie help... aka. headset baseplate doesn't fit fork
audiojan
by audiojan
My wife has a new Orbea Orca Dama that she's asking me to build up for her. Not a big deal since I've done all the wrenching on all our other bikes. EXCEPT, the darn headset baseplate doesn't push all the way down to the fork crown! It's a gap of about 15mm and it just won't go any further. What do I do?!
MajorMantra
by MajorMantra
Are you using a proper crown race tool, or something that passes for one?:
It can take a bit of force, and it needs to be applied evenly so it goes on straight and doesn't get stuck.
sungod
by sungod
^^^this
or you can improvise with a piece of pipe
either way, it needs a good whomp to seat a crown race
if it's an alloy steerer there's the outside chance that it hasn't been finished to allow fitting the race, but a cf steerer should be ready
to ease things, lightly grease the area where the race goes, heat the race before fitting (boiling water, no more than that)
goodboyr
by goodboyr
Its got a 1.5" lower bearing. Are you sure you've got the right size crown race?
audiojan
by audiojan
Yes, the crown race is the right diameter. That's the first thing I checked. I didn't use a press/tool, but I guess I need to improvise to get that seated. Thanks for the suggestion!
