It is currently Fri Feb 24, 2017 6:27 pm
Post new topic  Reply to topic  [ 18 posts ]  Go to page 1 2 Next
PostPosted: Wed Aug 14, 2013 1:13 am
I think i might be going crazy or this may have been discussed before.. but I just got upgraded to the new 11-speed dura ace and I put my Enve wheelset on that still has a campy cassette and the shifting works really well! Am I missing something?
PostPosted: Wed Aug 14, 2013 1:25 am
No, you're not going crazy.
The spacing between cogs on Shimano/SRAM and Campagnolo has always been the same if the cassette is the same speed.
Back in 10spd world, you could have used a Shimano/SRAM or Campagnolo 10-spd cassette with any 10-spd drivetrain system. How do you think those neutral support vehicles could just throw on any wheel and make it work? (Before the transitions of 11-spd started taking place)
The differences are only in the freehub splines, and the compatibility of shifter-to-derailleur. In the analog, there wasn't any noticeable incompatibility of shifter-to-front-derailleur, but now that Shimano and Campagnolo have both gone electronic, the incompatibilities are regardless of derailleur.
PostPosted: Wed Aug 14, 2013 2:34 am
Well the spacing is not the same, but the difference is so insignificant that they are interchangeable without any problems.
The difference in that range is actually so insignificant that you can use a 10 speed cassette with 11 speed shifters by limiting out the last gear.
PostPosted: Wed Aug 14, 2013 8:18 am
So, is it also possible to use 10 speed shifters on a 11 speed cassette?
Anyone tried that?
PostPosted: Wed Aug 14, 2013 9:03 am
10 speed cassettes spacing are not the same Shimano/SRAM = 3.95mm, Campagnolo 4.12mm e.g. Shimano/SRAM cassette on a Campag drivetrain
Center the chain exactly on 5th cog (best case) then shift to 10th cog the .17mm difference in spacing accumulates to .85mm overshift or about 22% error
center the chain on the 1st cog and it would over shift by 1.53mm 40% out, might shift but far from ideal.
Shimano/Campag 11 speed cassette spacing is close enough not to make any difference.
PostPosted: Wed Aug 14, 2013 11:17 am
In a German forum a guy measured the difference in spacing. It was 0.02mm... so your assumption is right! :thumbup:
PostPosted: Wed Aug 14, 2013 4:36 pm
11 speed shimano cassette will work on super record 11 drivetrain ?
2013 Look 695
PostPosted: Wed Aug 14, 2013 5:45 pm
I did notice a little turbulence in the middle of the cassette.
PostPosted: Wed Aug 14, 2013 11:07 pm
My Dura-ace 11 speed cassette is creaking like no bodies business, so I tested an 11 speed campy wheel on my Red22, works fine. If it works on SRAM it'll work in Di2.
PostPosted: Wed Aug 14, 2013 11:25 pm
@nismosr yes, test rode a 12-25 d/a 9000 on a full super record build today, was flawless barring one thing -the chain was catching the shift pins when in the small/small combo, though I think that may have been more a product of the wheel change/cassette position.
PostPosted: Thu Aug 15, 2013 7:14 pm
Did / can someone measure the cablepull on sram 11 speed shifters?
PostPosted: Thu Aug 15, 2013 8:20 pm
What about wheel dishing? My zipp 303 was sent back to the factory for 11 speed hub upgrade because they need to redish the wheels, and I have to buy a new Campy free hub body to work with the reddished wheel.
PostPosted: Thu Aug 15, 2013 11:57 pm
Don't understand this one at all.
Campy 11 spd cassettes work on 9 and 10spd freehubs just fine.
There's sometimes a buggy.
One.
PostPosted: Fri Aug 16, 2013 1:01 am
I have a Proton wheelset bought in 2002. An 11spd cassette jams into the spokes: it plain doesn't fit. I suspect I need a new freehub.
Less is more.
PostPosted: Fri Aug 16, 2013 2:02 am
Tubbie Guru
Hi,
How about a new brain?
A Little screwdriver would do perhaps?
Ciao, ;)
There are no new unread posts for this topic. Campy cassette on Di2 9070
coppercook62
11
1021
Thu Jun 02, 2016 1:00 pm
micro553 View the latest post
There are no new unread posts for this topic. Campy 11-29 cassette not compatible with EPS
audiophilitis
16
1347
Fri May 13, 2016 6:17 pm
audiojan View the latest post
There are no new unread posts for this topic. Campy SR DP brakes vs campy skeleton DP
JDEves
Tue Oct 11, 2016 8:39 pm
JDEves View the latest post
There are no new unread posts for this topic. S-Works SL 2018
ak47
9
2337
Wed Feb 01, 2017 7:17 pm
Tracerboy View the latest post
There are no new unread posts for this topic. Lightest QR that actually works well?
[ Go to page: 13 4 5 6 7 ]
TheDarkInstall
95
9605
Thu Nov 10, 2016 8:49 am
Marin View the latest post
Users browsing this forum: 4ibanez, elzilcho, lovemyway, snowdevlin, sovereign, Yahoo [Bot] and 33 guests
