It is currently Mon Feb 27, 2017 8:04 pm
Post new topic  Reply to topic  [ 3 posts ]
 Post subject: Anodized Cog Spacers?
PostPosted: Wed Aug 14, 2013 12:24 am
Has anyone come across anodized cog spacers for Shimano/SRAM 10-speed cassettes (or any cassettes for that matter). Just so it's clear, I'm talking about the 2.35mm (on Shimano/SRAM 10) spacers that fit between the smaller loose cogs.
FTWi CritBike
PostPosted: Wed Aug 14, 2013 12:48 am
2.35mm is not a standard material thickness so not so easy to make in small volumes. Shimano would have many economically viable methods to make these spaces at this thickness. They could reroll the sheet strips then punch the spacers out, or they could just forge them (less likely as wouldn't be as fast).
If you were to make them at low volume - you'd maybe have to mill down a 2.5mm sheet then laser cut? A lot of waste and work for a tiny low value part that not many people would likely want to pay even $1 each for.
OK sorry - no haven't seen them
PostPosted: Wed Aug 14, 2013 12:51 am
I think you would be better off just prepping and spray painting the ones already on the cassette. It's not like they will be in contact with anything (on the top of the spacers) that may scuff them up. Sand them up, paint them, clear coat. I painted some hubs that way, they were not loose they were on a completely built wheel. 5 years later, no flaking, chipping, cracks.
http://ddubcustomsportswear.com
There are no new unread posts for this topic. Campagnolo Overtorque crank missing spacers?
svm
Sun Jun 05, 2016 6:53 pm
bikerjulio View the latest post
There are no new unread posts for this topic. Bor RR688 crankset w/ rotor 4630 bb-spacers?
reedplayer
Thu Aug 18, 2016 1:52 pm
reedplayer View the latest post
There are no new unread posts for this topic. Negative GSL tuned brakes - use of padholder spacers and release lever
Slimtim
Sun Dec 11, 2016 11:32 pm
Slimtim View the latest post
Users browsing this forum: Bing [Bot], dak, Hamilton, lovemyway, mac567, Majestic-12 [Bot], MSNbot Media, mvnsnd, stevec1975, westwood, Yahoo [Bot], zazo and 32 guests
