wheel sets
to much trek involved
same old same old
same old same old
so far...king fast
A new forum-Cycling with Power...also a Junior Training section...come check it out!
www.cyclingpower.jconserv.net
I vote for 404 rear and 303 front. 404's on the front can be a handfull on a windy day and you can't controll the weather on a race day. I also feel the 404 rear is a little stronger/more durable than 303's because of the greater spoke angle.
For certain parts stiffer is more important than lighter.
PNuT Posted:
with an attitude like that at 15 you will have a whole plate when you grow up
i certainly will!!!
i certainly will!!!
so far...king fast
yourdaguy:I vote for 404 rear and 303 front. 404's on the front can be a handfull on a windy day and you can't controll the weather on a race day. I also feel the 404 rear is a little stronger/more durable than 303's because of the greater spoke angle
thats the thing though! the weather. thanks for the advice though! the stifness thing is not so important as i weigh 50 kg! it does make sense though
so far...king fast
JIGGY BOY wrote:yourdaguy:I vote for 404 rear and 303 front. 404's on the front can be a handfull on a windy day and you can't controll the weather on a race day. I also feel the 404 rear is a little stronger/more durable than 303's because of the greater spoke angle
The aerodynamics aren't that important either when you're that small...
Ridley Posted: Wed Jan 04, 2006 9:51 pm Post subject:
sorry how does that work?
so far...king fast
- Contact:
wow JIGGY BOY you're 15
I'm 17 where do you come from?
I would recommend you the AM-Classic CR-420 rims
with some light hubs and only a few spokes
cause you're featherlicht and can ride it.
I think 18/24 spokes are a good option,
but I think that's the only option cause the are only in 18/24 sold.
My opinion is the opposite: Aerodynamics are more important for smaller riders since they usually have less overall wattage a non-aero wheel will be a bigger overall percentage penalty for them.
I would go for the 404 simply because its the one wheel that you can have it all - lightweight and aero. Since its only 100g or so difference between the 303, but the 404 is more aero and frankly at 1200g, its lighter than most, and good enough for climbing. So unless you are climbing Col de Galibier or something similar, the 404 should be more than adequate for most applications.
Bikes4fun wrote:I would go for the 404 simply because its the one wheel that you can have it all - lightweight and aero. Since its only 100g or so difference between the 303, but the 404 is more aero and frankly at 1200g, its lighter than most, and good enough for climbing. So unless you are climbing Col de Galibier or something similar, the 404 should be more than adequate for most applications.
Botero on the Galibier:
second place... 'nuff said.
- TunedCannondaleR700
Go with the front and rear 404.
Cannondale is quite simply the best
I say go with the Ksyrium SL's. They are great for an all round wheelset that will be much more durable than Zipps, and they are quite frankly all you will need. I could continue on for a while about how carbon wheels are unnecessary at your age, but I'll spare you
before buying any carbon wheels,you may want to check the UCI rules for juniors, i know that there is a rule against u17s and younger riders are not allowed to ride carbon, aramid or any composite wheels, there are numerous rules like this which restrict juniors, such as the rule about having restricted gears and no aerobars for juniors, etc. For these reasons i would definately not reccomend that you buy zipps or carbon wheels of any sort as you will not be able to use them in any junior races, at the risk of being disqualified.
I have just moved into the u19s and am now allowed to use carbon wheels myself, i have been a junior in your position before, it would be a pity to spend all that money and only be allowed to use them for training
ride some metal clinchers and save your pennies till ure older.
Joe
Joe
i dont need some witty signature
