ricerocket
by ricerocket on Thu Sep 05, 2013 2:39 pm
justkeepedaling wrote:The R5 is a huge step away from the R3 SL. Completely different design...
That said, I'm hoping the pricing can be competitive with that from Felt otherwise, that's the way I go this year
Are you referring to the current ones or the new 2014 stuff?
The 2014s looks pretty similar, same Squoval 3 tubing, internal routing, etc. In fact, I'm failing to find what the difference is other than weight.
justkeepedaling
by justkeepedaling on Thu Sep 05, 2013 3:49 pm
Either of the R5s is a very different bike to the R3 SL from 2007 for example.
As far as 2014 R series go, the difference is the layup. Maybe a bit of stiffness and less weight. That's about it.
That's why I'm probably gonna get a R3, personally
uraqt
by uraqt on Thu Sep 05, 2013 5:19 pm
@ ricerocket
The 2014s are different bikes for sure, The 2014 R5 has a different fork and I think every "tube" is a different shape. : ) I am sure it's going to ride different.
That being said there was a difference between the R3sl and 2011-2013 R5 to, major changes to geometry and the lay up. The front end of the R5 is stiffer and there is more vertical compliance in the seat tube junction.
C
airwise
by airwise on Thu Sep 05, 2013 6:42 pm
My point was that, for instance, a Supersix Evo is a very different frame to my Supersix HM, but the unit cost to the consumer did not go up by 40% in the process.
GT56
by GT56 on Thu Sep 05, 2013 8:20 pm
justkeepedaling wrote:Either of the R5s is a very different bike to the R3 SL from 2007 for example.
funny how you guys talk about things you have no knowledge of (layup) and you miss what is there for everyone to see internal rear brake cable, Di2 - ready / Internal (Mechanical) Shift cabling, tube shapes
ricerocket
by ricerocket on Thu Sep 05, 2013 9:43 pm
Hey I have too, I'm also an FSAE alum.
Thanks for confirming what I thought. I'm most interested in seeing if they're just hitting the same stiffness figures w/ cheaper layup schedules, or if the R3 loses some stiffness to the R5. I'm not a huge weightweenie, despite my desire to be on this board.
I'm also curious how this is versus a Foil, Propel, or any other bike that's marketed as an aero road bike.
uraqt
by uraqt on Thu Sep 05, 2013 9:58 pm
@ GT56,
I am only 90% sure but think both Damon Rinard and Phil White have said that all their bikes have individual layups based on size and type of bike requirements. : )
C
justkeepedaling
by justkeepedaling on Fri Sep 06, 2013 1:15 am
ricerocket wrote:Hey I have too, I'm also an FSAE alum.
I work mostly with the aero group, but we do fabrication too. As far as what Cervelo showed in the white paper for the RCA, they showed superiority to the Trek Madone KVFs. I'm guessing the shape is better than the Foil but worse than the Propel/Venge/new S3/S5. It's probably not that far off the true aero bikes, though.
poppiholla
by poppiholla on Fri Sep 06, 2013 11:18 am
I would have loved to see some more colour at Cervelo 2014 bikes.
Specialized Tarmac S-works SL7 (Satin carbon spectraflair tint)
Specialized Tarmac S-works SL6 (Green Cameleon)
Specialized Tarmac Pro SL6 Disc (Blue/Teal Sram Force AXS)
Specialized Epic Elite 29
Greetings from the Netherlands
spartan
by spartan on Fri Sep 06, 2013 2:46 pm
cervelo white paper.....pg 21
watts saved
rca ----------- baseline
madone--------- 2.6
R5CA------------ 7.4
SL4--------------9.8
ssevo------------10.2
madone 725gm VS cerveloR5 808gm
madone seat clamp 130gm VS 27.2 180gm post
madone bb bearings 50gm vs rotor pf + 24 adapter 110gm
Current Rides:
2023 Tarmac SL7 Di2 9270
ex 2019 S-works SL6
ex 2018 Trek Madone SLR Disc
ex 2016 Giant TCRAdvanced Sl
ex 2012 Trek Madone7
