It is currently Thu Apr 27, 2017 4:20 pm
Post new topic  Reply to topic  [ 2 posts ]
 Post subject: 4za wheel decals
PostPosted: Sat Aug 10, 2013 10:22 pm
I've got a pair of 2011 4za 50mm carbon wheels, and I decided that I wanted to remove the decals for aesthetic reasons. The back wheel decals came right off, just had to use a knife carefully pushing enough of the decal up, so that I could just peel it right off.
The front wheel however is a whole different story. As to the back wheel I could easily feel that the decals could be peeled right off, the front wheel decals almost seems like they're painted on. I tried the hairdryer solution and no amount of heat does anything to it. It seems that easy solutions aren't an option anymore and I need to use a couple of hours to scratch it off or use acetone to dissolve the glue holding the decals though that doesn't seem like a good idea, so I'm asking you forum, what can I do?
 Post subject: Re: 4za wheel decals
PostPosted: Sun Aug 11, 2013 11:50 am
hmm, maybe the front ones are under a layer of clearcoat?
you could experiment on just the edge of one with acetone, isopropyl alcohol etc. and see if that will do it, acetone is commonly used for degreasing cf rims, i use it on mine without problems
fwiw i had some mavic wheels where the decals on one wheel came off easily, but on the other wheel were a nightmare, apparently identical stickers, big difference in tenacity
There are no new unread posts for this topic. Custom Frame Decals
SpecializedColnago
Fri Mar 03, 2017 9:49 pm
duvivr6 View the latest post
There are no new unread posts for this topic. Cannondale Frame Stickers/Decals
Valbrona
Mon Aug 08, 2016 7:12 pm
caad10dotcom View the latest post
There are no new unread posts for this topic. removing decals - 3T doric Ltd seatpost
Monkeychunki
Fri Mar 03, 2017 4:32 pm
DJT21 View the latest post
There are no new unread posts for this topic. Risk of removing DTSwiss decals?
greentimgreen
7
924
Tue Dec 06, 2016 11:15 pm
cadence90 View the latest post
There are no new unread posts for this topic. Help needed - dark green CAAD with yellow decals?
caadmium
Fri Nov 11, 2016 4:25 pm
caadmium View the latest post
Users browsing this forum: Baidu [Spider], Bing [Bot], huddini, leicaman, stubob and 37 guests
