DURA ACE 9000 CRANK will work with Campy 11 system?
by ehudk
Hi All,
Although a lot had been said about the different matches, couldn't find this issue.
I have a TREK MADONE 7, and I bought the DURA ACE direct brakes, since the original Bontrager got rusty...
But when I setup the rear brake, I found that the crank left arm is touching the rear brake.
I assume it has all to do with the Q-factor
So, before running to buy new DURA crank, I'm looking to find if it will fit with the rest of the record group (11)
10x, Udi.
by PSM
You just don't mix Shimano and Campagnolo.
Tinea Pedis
by Tinea Pedis
It's been covered in plenty of threads, it's fine.
I know, as I've done it (and replied to posts pertaining to it). Even 10sp Dura Ace crank works with 11sp Campag.
