It is currently Tue Oct 17, 2017 12:58 am
Post new topic  Reply to topic  [ 254 posts ]  Go to page 1 2 3 4 517 Next
 Post subject: Look Keo Blade 2 2014
PostPosted: Sat Aug 10, 2013 12:51 am
Saw this post
http://glorycycles.blogspot.hk/2013/08/ ... pedal.html
Looks like the blade is little more protected like Time's design?
AX Lightness Vial Evo, Carl Strong Titanium
PostPosted: Sat Aug 10, 2013 10:30 pm
Now that looks great. Me want!
  • LOOK Ko Blade 2 Cr 16
  • 121.9 EUR
  • Price includes 19% V.A.T. which will be deducted when goods are leaving the EU. Shipping costs may be added.
PostPosted: Sat Aug 10, 2013 11:36 pm
Looks not bad but i am sticking to my Dura Ace 9000 pedals. Shimano's bearings and reliability has won me over.
PostPosted: Sun Aug 11, 2013 12:02 am
Interesting that the tension now goes up to 20 from the previous 16 assuming the new 20 is still measured in nm the same as the 16 was. Wonder if it was a pro request type thing to have an even stronger/stiffer setting than 16nm?
Looks like I made a new 90 Proof friend
PostPosted: Sun Aug 11, 2013 6:55 am
20 nm seems high. Seems like most of my friends run their Keo 2 Max pedals in the easiest settings or close to it. I run mine pretty loose too.
PostPosted: Sun Aug 11, 2013 7:00 am
Do you know what NM equal the easiest setting on the Keo 2 Max? Thanks
PostPosted: Sun Aug 11, 2013 8:40 am
Easiest setting for Keo 2 Max (non carbon) would be 9 Nm according to look. They range from 9-15 Nm.
http://www.lookcycle.com/en/us/route/pe ... 2-max.html
Oddly they claim the Look Keo 2 Max Carbon is 12-18 Nm.
http://www.lookcycle.com/en/us/route/pe ... arbon.html
Not sure why they are different. I wonder if that is a typo.
PostPosted: Sun Aug 11, 2013 5:09 pm
More options are always nice, the 16s are stiff enough for me though. I don't find myself wishing for any more Nm in any case. Perhaps if you had zero float cleats you might want a stiffer spring though.
PostPosted: Wed Aug 14, 2013 12:16 am
Oooh, that pedal looks very clean. If I had more money I'd be getting a pair!
Regarding the tension, I only use 16NM carbon blades and I wouldn't mind getting a little more spring tension. I have never had a problem clipping in due to high tension and I have managed to pop a cleat loose accidentally while hauling my SS road bike at a high cadence (130 ish).
PostPosted: Wed Aug 14, 2013 3:40 am
Location: Lima, Peru and occasionally in the Washington DC area.
No issues with current blades at 16NM. The new ones do look nice and are light. Pleasantly surprised that Look has also finally resolved the dreaded cleat squeak that made me swear off the old Delta Looks...
@aftereffector, were your cleats worn, by any chance?
PostPosted: Wed Aug 14, 2013 9:06 am
Holy cow, $400 retail for pedals? :noidea:
Then again, if accurate, it's ~16g saving vs a pair of current Keo Blade Ti's, so who knows... :D
PostPosted: Wed Aug 14, 2013 9:09 am
I’m not an engineer but would guess the different length of “spring” and pivot point means they’ve upped the nm rating but maintained the same level of engagement tension as the old set up. Just a guess.
Pegoretti Responsorium, Parlee Z5i, Donhou Commuter, 1946 MacLeans Featherweight L'Eroica!, 2x MTB 'dales
PostPosted: Wed Aug 14, 2013 2:59 pm
@mrlobber, no reason to pay retail. Wait a wee bit and your Google fu skills will lead you to purchase these at a very significant discount on MSRP.
PostPosted: Wed Aug 14, 2013 11:23 pm
Yup, look at the MSRP of the current Blades then go on Ebay and look at some of the sellers with brand new in box sets for ~$140ish. Heck even on Ribble for example you can get them for roughly that amount or even a bit less depending on sales
  • 121.9 EUR
PostPosted: Thu Aug 15, 2013 2:54 am
Beautiful looking - and ever so slightly more aero too :)
2012 SuperSix - 6.30kg
There are no new unread posts for this topic. 2014 EVO and 2014 Madone 5.9 frame and brake weight
BLD25
Thu Jan 19, 2017 1:08 am
BLD25 View the latest post
There are no new unread posts for this topic. Look pedal washers and Keo Blade 2
liam7020
Wed Jan 25, 2017 1:03 am
liam7020 View the latest post
There are no new unread posts for this topic. Tarmac Pro SL4 2014
tarmacdz
Sun Jun 11, 2017 6:54 pm
tarmacdz View the latest post
There are no new unread posts for this topic. Cervelo S3 2014 - Internal battery conversion
Xcessiv
Wed Feb 15, 2017 12:01 am
hambini View the latest post
There are no new unread posts for this topic. 2012 Cannondale Slice 5 VS 2014 Stradalli Phantom II
Alpine318is
Tue Mar 14, 2017 7:43 am
jekyll man View the latest post
Users browsing this forum: 964Cup, albertop07, AZR3, Baidu [Spider], Bing [Bot], djbowen99, jwfinesse, kookie, morganb, seansis, Seedster, Yahoo [Bot] and 36 guests
