It is currently Sun Jul 23, 2017 4:05 pm
Post new topic  Reply to topic  [ 5 posts ]
PostPosted: Fri Aug 09, 2013 8:08 am
Hi weenies,
I just installed a 3d+ rotor crank on my bbright bike.
I use a 53 aero noQ chainring as outer and a non aero noQ 39 chainring on the inside.
I first installed the 39 with the bolts falling inside the cutouts on the 39 ring.
I got horrible chain rub with the inside of the 53 chainring, with the chain on the 53, it rubs aginst the inside of the 39.
Ofcourse this only happened with not straight chain line.
When i turned the 39 chainring around with the bolts NOT falling in the cutouts, all problems seemed gone.
Is this normal?
I couldnt find any documentation about installing the noQ rings on the web or at the rotor website.
Carboner
PostPosted: Sat Aug 10, 2013 12:00 am
Its a known issue. Recent shimano chainrings (7900 onwards) have wider spacing. I've used problem solvers chainring spacers (1.2 mm) to eliminate this. Just adjust your FD stops accordingly.
My RCA
PostPosted: Sat Aug 10, 2013 9:44 am
Ok good to know, strange thing was that the 39-27 straight chainline was really noisy.
I'll just keep the ring reversed.
Carboner
PostPosted: Mon Aug 12, 2013 6:12 pm
goodboyr, can you elaborate on how you're spacing your rings. I recently switched to q-rings from my praxis works rings and there is a definite difference in the thickness of the rings or at least how they are spaced on the same spider. Did you have to use longer chainring bolts? While the shifting and where the FD stops are now with the q-rings, it's pretty much at the limit. It's definitely livable but I feel it could be much better with some better spacing. Thanks
My Cervelo R5
My Lynskey Helix
My MTB
PostPosted: Mon Aug 12, 2013 6:20 pm
I don't have any experience with the q rings. I was answering the question for conventional non shimano rings such as "no q" rings and praxis rings. In those cases its simply a case of adding a spacer (0.6 or 1.0 mm thick) to the inside of the large ring (mating surface to crank spider) and using the existing bolts.
My RCA
There are no new unread posts for this topic. Standard chain rings to semi compact chain rings = new crank?
stockae92
11
952
Fri Sep 23, 2016 8:27 pm
topflightpro View the latest post
There are no new unread posts for this topic. Quarq Dfour with Rotor QXL rings
TroyG
Wed Apr 26, 2017 8:53 pm
TroyG View the latest post
There are no new unread posts for this topic. Sram Etap - Rotor Q rings
bruno2000
7
2454
Tue May 02, 2017 11:58 am
Philbar72 View the latest post
There are no new unread posts for this topic. AbsoluteBlack oval chain rings
BugsBunny7788
Tue Aug 02, 2016 5:18 pm
jrmynthn View the latest post
There are no new unread posts for this topic. FC-9000 crank with 56-44 rings or just the rings
lactatehate
Tue Apr 18, 2017 3:13 am
FIJIGabe View the latest post
Users browsing this forum: Bing [Bot], Donic, ghisallo2003, Google Adsense [Bot], JDEves, justaute, Merc86, sun, UTmtnbiker and 37 guests
