How long can a THM Clavicula crank last?
mises
by mises
The answer is at least 8 years in one case. My compact 175mm set, purchased at the end of July in 2005, has just developed a crack near the pinch bolts on the left crank. Averaged over the lifespan, a cost of $111 per year. Not bad for the WW crank category killer, but your results will almost certainly vary.
pawnii
by pawnii
My older non-drive side arm that used 2 pinch bolts also cracked. Damn thing wouldn't stop squeaking for the next 2 years.
2012 Scott Foil Premium
Juanmoretime
Administrator
by Juanmoretime
My Zipp VumaQuads lasted 5.5 years before they had a repairable failure. Cost $145 per year. I decided to sell them instead of re-bonding the insert on the drive side but I know its a doable repair so I guess they could have and are going longer but not on my bike.
Not bad. My 7 year old AX Lightness Sprint is still going strong.
RESIDENT GRUMPY OLD MAN.
xnavalav8r
by xnavalav8r
I've had a set since 2006. They required a repair shortly after I bought them... rebonding the insert for the fixing bolt, but have been trouble free since.
mises
by mises
pawnii wrote:My older non-drive side arm that used 2 pinch bolts also cracked. Damn thing wouldn't stop squeaking for the next 2 years.
:lol: 2 years!? Sounds like mine. If it wasn't getting worse I'd probably push my luck too, though it's probably not the smartest thing to do.
llhh
by llhh
Wouldn't it make more sense to talk about ball park mileage rather than years?
Parlee Z1 Super Record / ENVE / Campangolo Bora
pawnii
by pawnii
The 4 years i had them I had all sorts of problems. I brought them used off eBay...very bad idea.
Seems some bastard sold them to me after he crashed them.
-Aluminium bung that the pedals screw into fell out.
-Aluminium bung in the non-drive side arm for the per-load screw fell out.
-non-drive side arm carbon cracked around pinch bolt.
-spindle was compressed or worn where the BB bearing sits on. So the crank always has a little lateral play.
