It is currently Sun Jan 21, 2018 10:18 am
Post new topic  Reply to topic  [ 47 posts ]  Go to page Previous 1 2 3 4
PostPosted: Sun Aug 18, 2013 8:10 pm
Have you said whether you've tried a longer rear cable loop? Mentioned by @mises above.
The late 2009 spacer change was between cog 6 and 7 - 2.2mm to 2.3mm. I ran into this because I discovered this spacer was crushed/broken on my cassette. LBS warranteed it and said that Campy told them to do 15 nm on the lockring, not the 40 nm stamped on the lockring. I can't vouch for this second-hand info, but I wonder if you use a torque wrench on the lockring and do the full 40 nm, can it be so tight as to affect the spacing? I have no idea, just thinking out loud...
PostPosted: Mon Aug 19, 2013 11:32 pm
A further update from today's tinkering......
Tried an r-sys wheel with campy 12 up cassette and got it working pretty much spot on, then tried both the zipp wheel with said 12 up cassette and the r-sys with the problematic 11 up, neither worked flawlessly but were certainly an improvement. Leads me to think this issue is very much a product of freehub spacing (relative to the outside face of the hanger) along with cassette selection.
Though I don't think that tells the whole story as we have had this kind of set up working on other bikes without fault. It seems a combination of factors lead to a particularly sensitive set up in this case. This has certainly been an interesting experience for me as a mechanic and has sadly soured my view of campy somewhat :(
There are no new unread posts for this topic. Attachment(s) Advice from Experienced Campy Wrenches Please!
colnagoc59
24
1695
Sun Sep 03, 2017 4:23 pm
colnagoc59 View the latest post
There are no new unread posts for this topic. Advice needed from experienced WW
Mtek
Fri Aug 11, 2017 6:15 am
stormur View the latest post
There are no new unread posts for this topic. Chorus 2015+ users
Boshk
Fri Dec 15, 2017 11:31 am
Digger90 View the latest post
There are no new unread posts for this topic. Users of the Fabric bottle cage system, opinions please.
burglarboycie
10
1367
Tue Jul 18, 2017 2:36 pm
Mrseasons View the latest post
There are no new unread posts for this topic. Carbon fiber spokes + Alloy Rim = DISASTER(for MAVIC users)
[ Go to page: 1 2 3 4 5 6 ]
ohhyeok90
80
5588
Thu Nov 16, 2017 9:57 pm
antonioiglesius View the latest post
Users browsing this forum: Bing [Bot], fromtrektocolnago, tomyboy123 and 26 guests
cron
