It is currently Tue Jan 16, 2018 12:57 pm
Post new topic  Reply to topic  [ 9 posts ]
PostPosted: Wed Aug 07, 2013 2:32 pm
i recently installed an iLink brake cable set but didn't weigh it prior.
Any else here weigh them prior to installing them?
cheers
2012 Scott Foil Premium
PostPosted: Wed Aug 07, 2013 2:45 pm
cheers
Somewhere between 100-120g depending on bike size. If you are using mini for shift that is. 20-30g more with regular iLink for shifting
PostPosted: Wed Aug 07, 2013 2:47 pm
is that 100-120 for both brake and shift?
I've just got brake as my bike runs Di2.
PostPosted: Wed Aug 07, 2013 2:59 pm
55-60 for brakes only
PostPosted: Wed Aug 07, 2013 3:16 pm
The outer is 26.5g per meter approx and the liner 1.4g per meter. Then add a few grams for any ferrules.
PostPosted: Wed Aug 07, 2013 3:26 pm
ah thanks guys.
So what would the average weight be for front and rear brake inner cables?
PostPosted: Wed Aug 07, 2013 3:53 pm
Weights for them and comparisons to other kits can be found here: http://fairwheelbikes.com/c/forums/topi ... #more-3149
Fair Wheel Bikes
Fair Wheel Blog
Instagram
PostPosted: Fri Aug 09, 2013 12:56 am
thanks madcow.
exactly what i wanted.
PostPosted: Fri Aug 09, 2013 9:14 am
@ pawnii,on my 56cm Addict frame,the rear brake inner is 17g and the front brake inner is 8g.
There are no new unread posts for this topic. Alligator Ilink / Mini Ilink
Luca79
Tue Apr 04, 2017 12:34 pm
Mep View the latest post
There are no new unread posts for this topic. Attachment(s) Routing rear brake cable
Lightweenie
19
907
Wed Nov 29, 2017 10:27 am
Fiery View the latest post
There are no new unread posts for this topic. Fluo brake cable housing?
jever98
Wed Mar 15, 2017 7:11 pm
Kurets View the latest post
There are no new unread posts for this topic. C60: rear brake cable in the top tube
TonyM
Sat Sep 16, 2017 6:52 pm
Zakalwe View the latest post
There are no new unread posts for this topic. Gear/Brake cable set for internally cabled S-Works
JBC2
Sun Jan 14, 2018 10:48 am
marcelflash View the latest post
Users browsing this forum: asa226, Baidu [Spider], Bing [Bot], liam7020, lovemyway, nemomaya, TurboKoo and 25 guests
cron
