It is currently Sun Feb 19, 2017 10:55 pm
Post new topic  Reply to topic  [ 28 posts ]  Go to page Previous 1 2
PostPosted: Sat Aug 10, 2013 8:42 am
If I swap my 10 speed Novatec hub for an 11 what are the odds that I would be able to reuse my CX-Rays?
PostPosted: Sat Aug 10, 2013 5:43 pm
You'd have to put both hubs into a spoke calculator to see if your spoke length will work.
PostPosted: Sun Aug 11, 2013 6:23 pm
I just switched rear hub from Novatec's 10-speed F482SB-SL to 11-speed F482SB-11 and reused the spokes...the specs are extremely close...but make sure and replace the nipples...
2011 Tarmac Pro SL3 Project Black (gone but not forgotten)
2012 Parlee Z5 SLi (just because)
2014 Colnago C59 (why not)
PostPosted: Sun Aug 11, 2013 9:27 pm
I might be soon in the same situation as you guys so thanks for sharing the info. :beerchug:
My current ride
PostPosted: Wed Jun 04, 2014 9:33 pm
Can anyone help... have a Novatec F482SB Shimano hub that currently has a 10 speed cassette on it. I want to switch to 11 speed, but don't know if my freehub is compatible or if I can go down the Campag freehub route for 11 speed?
www.flickr.com/carlos_the_great
PostPosted: Sun Jan 18, 2015 11:45 am
Anyone has tried the Campy hub route on the older 10speed F372SB?
PostPosted: Tue Mar 10, 2015 1:08 pm
various sellers- amazon, for instance, has started to offer the F372SB in an 11 speed compatible format. I ahve one on order ( got it cheap). I'll update if it works out.
http://www.amazon.com/Novatec-A271SB-F3 ... B00IJYUOEG
PostPosted: Tue Mar 10, 2015 9:38 pm
I convert novtec hus all the time to 11 speed works fine.
www.thecycleclinic.co.uk
PostPosted: Wed Mar 11, 2015 12:10 am
Specifically the 372sb? Other Novatec hubs have long had 11 spd bodies available, the 372 hasn't...
PostPosted: Wed Apr 15, 2015 12:03 pm
in what way?
PostPosted: Wed Apr 15, 2015 9:53 pm
That may be the case, but this thread is primarily about older Novatec hubs which could not be converted by simply swapping the freehub body due to spacing issues of the hub body.
PostPosted: Sat May 02, 2015 2:57 pm
solved ImageImage
PostPosted: Sun May 03, 2015 3:38 pm
I've done recently the same on a pair of Gigantex wheels with Novatec hubs and it works perfectly. :beerchug:
My current ride
There are no new unread posts for this topic. solved
vilegnus
Thu Aug 18, 2016 4:12 pm
vilegnus View the latest post
There are no new unread posts for this topic. Freehub exploded, how bad is it? [PIC]
Shrike
Tue Aug 30, 2016 8:48 pm
Shrike View the latest post
There are no new unread posts for this topic. a freehub question
paregreen23
Wed Oct 19, 2016 9:59 pm
paregreen23 View the latest post
There are no new unread posts for this topic. Dura ace Hub - Ultegra freehub?
damond
Tue Sep 20, 2016 2:31 pm
damond View the latest post
There are no new unread posts for this topic. Chewed Up Freehub Bodies - How Much Is Too Much?
McGilli
11
1123
Sat Oct 01, 2016 8:48 am
Mackers View the latest post
Users browsing this forum: aerozy, Bing [Bot], dcaspira, JLS, silver62, snowdevlin, Yahoo [Bot] and 55 guests
