It is currently Sun Feb 26, 2017 1:32 pm
Post new topic  Reply to topic  [ 124 posts ]  Go to page Previous 1 2 3 4 59 Next
PostPosted: Sun Aug 18, 2013 8:40 am
ScottGoBlue wrote:
So, if you are planning on moving to Ultegra 6800, it sounds like the recommendation would be to spend a little extra and use the Dura Ace 9000 Front Derailleur? A quick search and this looks to be an extra $70 ... I'm OK with that.
Scott
With the 9000 cables (which I must stress, have had some issues on mine and my team mates bikes) I'd say it'd be a good move. And leave you with a group that shifts better than 7900/not all that short of 9000.
http://www.nicksquillari.com.au
PostPosted: Thu Aug 22, 2013 12:06 am
What was your issue with the cables? Are these the ones that retail at £20 each?
I'm about to be issued a warranty Addict R3 frame and am contemplating Shimano 11 after years on Campag 10. Trying to figure out what cocktail of parts would suit me. I really like the 9000 aesthetic so I have a feeling I'm going to want DA everything except the 9000 cassette (and maybe chain), but I'm agonising. The price jump is pretty big but I fear a mixed groupset would offend my eyes.
If aesthetics weren't an issue, what would be the best performance/£ combination? I'd guess 9000 STIs and FD, with 6800 everything else. What do we think?
Blog: http://thesetbackpost.com/
PostPosted: Thu Aug 22, 2013 12:18 am
The mix of aesthetics would ruin it for me....I ordered all the parts on eBay and spent less than $1,300 to upgrade to DA 9k.....I think 6800 is going for 1k, so price isn't that big of an issue.
Mosaic RS-1
http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=138478
Cielo by Chris King Cross Racer
http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=134376
PostPosted: Thu Aug 22, 2013 3:27 am
6800 is under $800 shipped.
PostPosted: Thu Aug 22, 2013 3:45 am
Where can you get it for under 800??
Sent from my One X using Tapatalk 2
PostPosted: Thu Aug 22, 2013 3:46 am
Yeah....never saw it for that low. I have actually seen 6700 going for $700+ for new.
Mosaic RS-1
PostPosted: Thu Aug 22, 2013 5:01 am
My input;
I went from 7900 to 9000 early this year. 9000 is definitely lighter, slicker, sexier, crisper, more refined, better looking, etc.
I broke the RD shift cable after 3 months use though, inside the shifter. Getting it out was a bit of a pain, but only took about 10 mins. I checked the cable route and everything was/is perfectly smooth and direct, so I can only put this down to the cables not being particularly long lasting. They are mega slick though, so maybe this is the trade off.
Overall it is excellent. Definitely more sensitive to set up though, and unlike 7900 which you could pretty much install whilst wearing boxing gloves, 9000 needs a gentler, more considered touch. Small adjustments seem to make a big difference, unlike 7900 which you could get basically in the right zone and it would shift fine.
I have not ridden 6800, but if it is slightly less pro than 9000 it is still going to be absolutely brilliant.
PostPosted: Thu Aug 22, 2013 5:06 am
I think one question is whether ~260g in weight savings is worth the 2-3x increase in cost to move from 6800 to 9000. Yes, there are other benefits like aesthetics, refinement, longevity...etc. that DA might offer over Ultegra. But Ultegra ain't a bad option imo.
I think a more interesting question for myself would be 6870 vs 9000? Might lean towards 6870 on that, especially if I had a frame that was designed for internal Di2.
PostPosted: Thu Aug 22, 2013 6:20 am
Mentioned in another thread, but my team (myself included) are all having this issue with 9000. Apparently it's due to the inner lining out the outer. It bunches up, causes friction and destroys the cable.
Whatever the case, it's a longer lasting cable design off being as close to faultless as any mechanical grouppo on the market today. Personal preferences, of course, notwithstanding.
PostPosted: Thu Aug 22, 2013 6:47 am
tranzformer wrote:
it seems like some think DA lasts longer and others argue Ultegra lasts longer.
It probably depends on the failure mode.
I've found for sheer durability, shift after shift after shift, the "working" bits of D-A just last. Forever. (Brakes, shifters, Fr/Rr mechs, Hubs) 4 or 5 seasons is doable, given a lack of crashes and extreme weather. Ultegra will do a couple before it gets sloppy and too annoying to race on.
Soon as you start adding in the consumables, Ultegra begins to look more sensible. (Cassettes mainly, as D-A chainrings last rather well compared to Ultegra). 2 ultegra cassettes a season, 3 D-A, maybe 4. (only used two D-A cassettes, ever. Bought at the same time on a deal, both worn out before the season was over. Stuck with ultegra after that)
Once you stick a bit of salty corrosive sweat and road salt/grime, rain and so on into the mix, i found that the D-A started to deteriorate much faster. Maybe this is as it's more refined and susceptible to the degradation, or maybe its cos the odd missed shift on a manky Ultegra groupset is acceptable, as opposed to a manky D-A groupset........ on my training bike, D-A shifters only lasted 16-18 months before i got fed up with missed shifts, then they got binned, the Ultegras that replaced them are still in use, 7 years later.
This is all on older stuff, but i suspect the same still applies. Roughly.
PostPosted: Thu Aug 22, 2013 7:19 am
^ what he said.
if you ride any amount of sensible miles, in rough weather, or race, the durability of dura ace quickly becomes a moot point. with the money I'd save on a DA vs ultegra I could near afford to get an almost new ultegra groupset a year down the road if it fails.
I would however, go with the DA crank over ultegra. looks badass, cranks don't wear out, and it's lighter.
PostPosted: Thu Aug 22, 2013 12:02 pm
Ah nice one for supporting my theory! I had some people claiming I had installed it wrong / had somehow caused the snapping on another forum.
Right, so this is an issue then.
And yeah, aside from this, 9000 really is amazing.
PostPosted: Thu Aug 22, 2013 12:50 pm
did you use the 9000 specific ferrulles at the shifters ?
PostPosted: Thu Aug 22, 2013 1:39 pm
Are the cable breakages always occurring at the same point?
PostPosted: Thu Aug 22, 2013 1:58 pm
Of course.
There are no new unread posts for this topic. Aftermarket brake choices for Shimano 6800/9000
ultyguy
Wed May 11, 2016 6:46 am
Anders3404 View the latest post
There are no new unread posts for this topic. Shimano 5800/6800/9000 crankset with a Sram 10S setup
LouisN
Tue Sep 27, 2016 7:45 am
kulivontot View the latest post
There are no new unread posts for this topic. Ultegra vs Dura Ace brakes (6800 - 9000)
iliedanila
28
6270
Sat Sep 17, 2016 1:26 am
5DII View the latest post
There are no new unread posts for this topic. any difference between rotor bolt covers of 6800 and 9000?
pavel
Fri May 20, 2016 3:53 am
Dez33 View the latest post
There are no new unread posts for this topic. Shimano Ultega 6800 pedals-bent axle
rOYk
Wed Apr 06, 2016 4:46 pm
kkibbler View the latest post
Users browsing this forum: Baidu [Spider], jimaizumi, mrgray, sivan, themidge and 37 guests
