Di2 Cable question
sjc166
by sjc166
Schoolboy question: I am looking at upgrading my groupset to DA 9070 Di2. I want to start buying different components over the next few months but i want to start with the cables next week. Are the correct cables to buy the EW-SD50? I have been doing research about it but like most things, the more you read the more confused one gets. So when i get confused i turned to the best cycling resource in the world. Any help would be great. Cheers.
freeloader
by freeloader
When in doubt, it's always best to refer to the official documentation :) -
http://si.shimano.com/#seriesList/46" onclick="window.open(this.href);return false;
crossifino
by crossifino
What do you currently have ?
Shimano sell a electric shifting kit which includes leavers, front and rear derailuer and battery...
If you are going from 10 speed might be worth just buying as a complete group it will be cheaper.
Cross
Omiar
by Omiar
Yes. You need 6 wires in total
* 2 wires from shifters to front junction box
* 1 wire from front junction box to "central" junction box SM-JC40/SM-JC41
* 1 wire from junction box to battery
* 1 wire from junction box to FD
* 1 wire from junction box to RD
Cables are not included in groupsets or upgrade-kits.
Scott Foil Ultegra Di2
Scott Scale 35 26"
Scott Spark LTD 29" M8000
sjc166
by sjc166
freeloader wrote:When in doubt, it's always best to refer to the official documentation :) -
http://si.shimano.com/#seriesList/46" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;
Cheers! Great resource
sjc166
by sjc166
Thanks. I was looking online at the Shinamo Line up chart http://productinfo.shimano.com/lineupch ... speed=2x11 and it has EW-SD50-I as the cables i need but i see stores have EW-SD50...i am guessing these are the same thing?
Omiar
by Omiar
Their the same. All the new gruopsets use the so called E-Type wiring. You can mix 9070, 6780 and 6770 components for example.
Scott Scale 35 26"
goodboyr
by goodboyr
Only difference is the "I" type are internal and come with zip ties on them to keep them from rattling in your frame.
Sent from my SGH-I747M using Tapatalk 4 Beta
pdlpsher1
by pdlpsher1
I'm also in the process of upgrading to 9070. Attached below is a list of parts you need and their approx. street prices. GL.
2 Shimano Ultegra Di2 EW-SD50 Connecting Wire 300mm $27.80 $55.60
1 Shimano Ultegra Di2 EW-SD50 Connecting Wire 350mm $28.65 $28.65
1 Shimano Ultegra Di2 EW-SD50 Connecting Wire 600mm $26.79 $26.79
1 Shimano Ultegra Di2 EW-SD50 Connecting Wire 650mm $28.67 $28.67
1 Shimano Ultegra Di2 EW-SD50 Connecting Wire 850mm $28.17 $28.17
1 Shimano Ultegra Di2 SD50 Wire Grommet Kit GM01 4PC $4.11 $4.1
1 Shimano Dura-Ace Di2 ST-9070 STI Levers $659.36 $659.36
1 Shimano Dura-Ace Di2 FD-9070-F Front Derailleur $392.41 $392.41
1 Shimano Dura-Ace Di2 RD-9070 Rear Derailleur $610.01 $610.01
1 Shimano Dura-Ace CS-9000 11 Speed Cassette 12-28 $249.95 $249.95
1 Shimano Dura-Ace CN-9000 11 Speed Chain $52.29 $52.29
1 Shimano Dura-Ace Di2 Front 5 Port Junction SM-EW90B $137.33 $137.33
1 Shimano Ultegra Di2 SM-JC41 Internal Junction Box $31.31 $31.31
1 Shimano SW-R600 DI2 Remote Climbing Shifter $124.61 $124.61
1 Shimano DuraAce Di2 BTR2 Internal Battery $199.99 $199.99
1 Shimano Di2 Internal Battery Charger SM-BCR2 $84.95 $84.95
1 Ritchey Logic Di2 Seatpost Battery Mounts $9.97 $9.97
ultimobici
by ultimobici
crossifino wrote:What do you currently have ?
Cross
Do they? Some retailers may do packages, but Shimano just sell the items singly as there are too many permutations to suit different frames/needs.
pdlpsher1
by pdlpsher1
Cross
There are some group packages out there but all of them to my knowledge use the external battery. I'm all for saving money however in the end I decided to order my parts a la carte. Plus I don't think one could save a huge amount buying as a group as far as Di2 goes. I also believe that Shimano gave OEM manufacturers much better pricing on Di2 than what's available to those wanting to upgrade. In other words it might be cheaper to buy a brand new bike with Di2 8)
sjc166
by sjc166
Great list, thanks. I have everything you put down except I see you put "Shimano Dura-Ace Di2 Front 5 Port Junction SM-EW90B". Do you know if the Shimano SM-EW67A-E will work as well?
pdlpsher1 wrote:I'm also in the process of upgrading to 9070. Attached below is a list of parts you need and their approx. street prices. GL.
Omiar
by Omiar
SM-EW67A-E will work, but
* only with external battery! SM-EW90B has a port to plugin the battery charger for internal battery.
* you need only 4 wires then when using SM-EW67A-E
Scott Scale 35 26"
sjc166
by sjc166
Thanks Omiar! I am on the right path again thanks to fellow WW's.
pdlpsher1
by pdlpsher1
You don't really need a five port junction A unless you have a very specific time-trial setup. However I did hear something about the five-port being wireless capable with the vaporware Flightdeck. When I checked the price between the five-port and three-port the difference was less than $10. I ordered the five-port just to be safe. Rumor has it the new flightdeck is ANT+ capable and it might be a good alternative to the Garmin (i.e. no need for a cadence sensor). GL.
