It is currently Sat Jun 24, 2017 10:16 am
PostPosted: Thu Aug 01, 2013 12:14 pm
I think I know the answer to this but just in case - has anyone tried actually baking their heat moldable shoes (eg Bonts, High level Shimano's) with (Look) cleats still on - ie just chuck em in the 100 degree oven without removing the cleats?
Im assuming the rubber grip point on the cleat is an issue which is why Ive always taken the cleats off before molding for the 2nd or subsequent time, but I may be wrong..
PostPosted: Thu Aug 01, 2013 2:41 pm
Yeah, any cleats that have some sort of plastic/rubber in them probably shouldn't be baked.
PostPosted: Thu Aug 01, 2013 3:30 pm
Also the cleats will not let you place the shoe flat to help mold the tub when soft. It will push in the sole in the wrong places.
PostPosted: Thu Aug 01, 2013 3:32 pm
^^^ Applies to Bont Shoes.
Shimano Shoes, Spiuk and other brands are different from Bont. Bont will shape the 'tub', whereas other brands have the technique affect the upper, not the sole.
The High-Level Shimano shoes are not baked, they're heated up a bit. It is best to do this at a Shimano dealer (if you did not buy the shoe from them there should be a minor charge). They will take your shoes - with cleats on - heat them up (not baked), then you put them on and your entire foot+shoe is vaccuum pressed together for about 90 seconds. Technically speaking you can achieve the results of the Shimano-fit by doing a few long rides in high temperature conditions and exposing them to the sun for long enough to heat up, but actually going to a dealer and getting it taken care of is far more efficient.
Regardless, the plastic of the cleats should be at a higher melting point than the materials or resins of the shoes.
PostPosted: Thu Aug 01, 2013 3:39 pm
They should be, but without any evidence to that point, it's definitely better to assume that they're not.
Besides, it's a minute of effort to remove and install the cleats, is a minute really killing anyone?
PostPosted: Thu Aug 01, 2013 4:35 pm
Yes. 108 people die each minute across the world. How could you be so thoughtless!!!
</sarcasm>
But seriously though: if you've had your cleats positioned through a rather elaborate fitting session, you may not be keen on moving those cleats.
PostPosted: Thu Aug 01, 2013 6:31 pm
Mark the edge of the cleat, on both sides and at the base, with a paint pen or silver sharpie.
PostPosted: Thu Aug 01, 2013 7:33 pm
What happens to those marks when you shove your shoes in the oven?
I do take the point about not being able to press down with cleats fitted though, hadnt really thought that one through.
As an aside, these, Shimano R241B´s, are my third set of "heat moldables", and I find they are the first ones which are really "plastic" and can deform noticeably. Previously I had a great pair of the old Shimano 310s which my dog ate, then a pair of Bonts which Ive worn through the upper on a crank rub, and I found those two never really "Moulded" to my feet. Both were comfy, but not sure how much of a change vs when I first wore them..
The current pair are 1/2 size smaller and Ive found that pushing them out (ie with a couple of pairs of socks) is easier than the whole vacuum "shrinking" to fit which the shop did on the 310s.
PostPosted: Thu Aug 01, 2013 7:45 pm
I've used those pens when marking up Kydex, which also goes in the oven, and it's fine.
PostPosted: Sat Aug 03, 2013 3:34 am
Mmm, Kydex. Just added some custom molded Kydex to my collection. Very nice draw and retention without having to break in customer leather.
Sub-5.8kg / 12.7lbs Addict SL w/PowerTap
9.3kg / 20.5lbs Scale 29 Pro ... woefully under-used
Retired: 5.9kg / 13lbs Addict R1 w/PowerTap ... lowest was 5.593kg / 12.33lbs
There are no new unread posts for this topic. SPD-SL Blue Cleats - Easier to Unclip than Yellow Cleats
ipenguinking
22
2111
Sun Dec 04, 2016 9:54 pm
ms6073 View the latest post
There are no new unread posts for this topic. Di2 stops working in the heat
obachman
21
1486
Fri Jul 22, 2016 12:38 pm
XCProMD View the latest post
There are no new unread posts for this topic. Heat Shield for Disk Brakes?
krtassoc
11
782
Thu Oct 06, 2016 9:44 am
mattr View the latest post
There are no new unread posts for this topic. Source for bebop cleats?
glepore
7
608
Sat Apr 01, 2017 9:17 pm
glepore View the latest post
There are no new unread posts for this topic. Shoes, shoes, not all of them created equal
vejnemojnen
13
1304
Wed Apr 19, 2017 11:57 am
Junior7 View the latest post
Users browsing this forum: Bing [Bot], Google Adsense [Bot], KB and 43 guests
