It is currently Wed Jun 28, 2017 6:58 pm
Post new topic  Reply to topic  [ 16 posts ]  Go to page 1 2 Next
PostPosted: Thu Aug 01, 2013 8:31 am
Currently running a Rotor 4130 on my Scott CR1.
Only been in 1000 miles and one side is running very rough.
Now I'm told by another Scott owner who also runs a Rotor chainset that he has gone through 3 bottom brackets in just 15 months! 2 steel and one ceramic.
Anyone suggest a more durable replacement? Lightweight would be very nice I think the 4130 is around 46g.
Looked at a Chris King but the price at £177 plus a weight of 101g is a put off although having owned King products in the past I know how durable they are.
Suggestions?
PostPosted: Thu Aug 01, 2013 8:27 pm
Although FSA appears to have introduced a new bottom bracket with dual row bearings on each side that would be compatible with the Rotor 3D+, not sure when it will be available to the public.
PostPosted: Fri Aug 02, 2013 7:13 am
Would this work?
http://www.fullspeedahead.com/products/ ... C-BB-PF30-
So unsure of how these standards work.
PostPosted: Fri Aug 02, 2013 10:45 am
Looks like that is for PF30 only. You need BB86 compatibility.
PostPosted: Thu Aug 08, 2013 8:59 am
Has anyone here used a Chris King PF30 with Rotor 30mm spindle cranks?
Inflicted some damage to the Rotor ones removing from the bike to add in some Loctite. I think King despite price and weight could be the way to go.
PostPosted: Thu Aug 08, 2013 10:48 am
gazzaputt, as I mentioned in my previous post you need BB86 compatibility. The Chris King doesn't seem to be compatible.
The problem you've got is that the 3D+ has a 30mm axle. The BB86 standard is based around the 24mm axle (Campag 25mm also works). Using a 30mm axle with the Rotor adapter reduces the bearing size and increases the chance of wear.
ms6073 has mentioned about the FSA BB that tries to reduce this problem with two rows of bearings. Basically there isn't much choice because the sytem is flawed and is really just a workaround.
If you had the 3D with the 24mm axle you could use one of the "standard" bottom brackets.
PostPosted: Thu Aug 08, 2013 7:30 pm
There is an Enduro solution, according to this article. I have no experience with it.
http://www.bikeradar.com/news/article/e ... -in-36675/
PostPosted: Fri Aug 09, 2013 11:14 am
Aspire Velotech are telling me that the King PF30 will work with Rotor 30mm spindles.
I've emailed Chris King to verify this.
PostPosted: Fri Aug 09, 2013 1:55 pm
The King PF30 certainly will work with Rotor 30mm, but I think NOT in a BB86 bike. The issue isn't just BB/Crank compatibility but your bike BB standard as well. One solution would be to change cranks to a 24mm spindle and use King PF24.
PostPosted: Fri Aug 09, 2013 2:54 pm
I currently use the Rotor 4130 with the 3d+ cranks which is fine but the bottom isn't that durable as I have said.
The Enduro looks good but cannot find as yet in the UK
I think your right the Chris King does not fit a BB86 shell.
PostPosted: Fri Aug 09, 2013 3:04 pm
Thanks gazzaputt :wink:
PostPosted: Tue Nov 17, 2015 12:17 pm
Any experiences meanwhile ? I have a Scott Foil frameset (BB86) and I would like to run a 30mm crank, so I need this 4130 bearings/BB solution (or like someone said above, workaround) but I'm really concerned about their durability...
Scott Foil Team Issue
PostPosted: Tue Nov 17, 2015 12:22 pm
I think like that is for PF30 only. You need BB86 compatibility.
PostPosted: Tue Nov 17, 2015 12:32 pm
4130 BB is exactly for this, running a 30mm axle into a BB designed for 24mm axle. Which is possible, the only concern is the life of those bearings...
PostPosted: Sat Nov 21, 2015 2:28 am
The Enduro BB works well. I've installed a few in some of my customers bikes that have a BB86 shell. Just make sure you don't over-do the preload, it's easy to cook bearings that small when they aren't ACBs.
There are no new unread posts for this topic. Need help on bottom bracket
poppiholla
Tue Jul 05, 2016 9:38 pm
poppiholla View the latest post
There are no new unread posts for this topic. Shimano pressfit 86 to Sram pressfit GXP
itguy
23
955
Thu Dec 22, 2016 11:02 pm
DMF View the latest post
There are no new unread posts for this topic. C60 bottom bracket removal
markyboy
Sat Jul 16, 2016 6:56 am
ianSWBB View the latest post
There are no new unread posts for this topic. Attachment(s) Bottom bracket 386 for Cipollini
MiddMan
11
418
Sat Jun 24, 2017 3:03 pm
Calnago View the latest post
There are no new unread posts for this topic. CAAD 10 Bottom Bracket
FastPants
Fri Oct 07, 2016 1:48 pm
FastPants View the latest post
Users browsing this forum: Bing [Bot], dak, gceniza, nemeseri, spartan and 51 guests
