It is currently Wed Jan 17, 2018 10:05 am
PostPosted: Wed Jul 24, 2013 7:31 pm
Which would you prefer and why? Main difference between Campi and Force?
SRAM advertises that the 22 has to be bought as a set, I am interested if the Crankset needs to be 'part of the set' or will SRAM Force/Red previous generation work as well?
PostPosted: Wed Jul 24, 2013 7:47 pm
I don't see why the old crankset wouldn't work. Unless it's radically different, I use 10s Rotor NoQ rings with my Campy 11s with no problems.
2016 Cannondale SuperSix EVO Hi-MOD IN PROGRESS
2014 Cannondale SuperSix EVO Hi-MOD, 5.79kg RETIRED
2014 Cannondale CAAD10, 6.83kg RETIRED
PostPosted: Wed Jul 24, 2013 8:01 pm
No doubt this thread will go the way of many other grouppo vs threads. But, fwiw, I would actually hold off for Ultegra 11s. If that brings the same improvements over 6700 as 9000 did to 7900, then it will (imo) be the best option for a budget 11 speed. Its fair to say if you buy any one out of Athena/Force22/Ultegra6800 you will be getting a great groupset. Your choice should be dictated more by ergonomics of the hoods and levers relative to your hands, compatibility with frame wheels and ease of service/availability of spares.
PostPosted: Wed Jul 24, 2013 8:29 pm
I am a bit sick of 105's. And I terribly want 11 speed over 10 speed since I almost never go down to the lower front ring. 11-28 cassette would be really nice :-) for Grand Touring Cyclist.
Are there any indications that Ultegra 11's will be on par for price / weight with SRAM Force?
PostPosted: Wed Jul 24, 2013 8:48 pm
As a mechanic, I'd always try to advise appropriate choice of ratios relative to terrain so you use both rings regularly ie if you live somewhere pan flat use 53/46 or similar if you live somewhere hilly that needs a 34 or 36 ring instead use compact. Though I do understand people who do a great deal of touring need a wider gear spread. On that point I think both force22 and 6800 will have a 11-32 option which combined with a 52/36 crank will give a very wide range.
I'm not that up to date with prices tbh, but I would imagine they'll be close to their outgoing counterparts. As for weight, I'm sure the guys at fairwheel will have that covered as soon as production units come into stock.
PostPosted: Thu Jul 25, 2013 8:58 am
Your primary consideration should be shifter ergonomics. I have only played with SRAM Red 2012/13 shifters in a bike shop; no experience with them on a long ride. That said, I have owned a SRAM Rival groupset before; the SRAM Red 2012/13 shifters, which are similar in shape and function to SRAM Force 22 shifters, are more ergonomic IMHO.
Compared to Campagnolo 11-speed shifters, however, Campy still wins by a mile in ergonomics (I ditched the Rival in favor of Chorus 2013). If you've got small hands, you'll enjoy how Campy ergo shifters are shaped and operated. Then again, you have to try them for yourself. Not all are fans of the thumb shifters; as far as I am concerned, I'm a big fan of them.
Next would be gearing options. As far as I know, the largest Campy cassette only run up to 29t, as opposed to 32t for SRAM (if you're going for the WiFli option).
As for Ultegra 6800, I've laid my hands on a groupset in a local bike shop. Given that I've got small hands, I didn't enjoy playing with the 6800 shifters. While they're better ergonomically than the 6700 shifters, they're too big for me. Also, there's still that slop (that is, that "dead space" before shifting is engaged). If you don't like instantaneous shifting that may result in accidental up- or down-shifting, it may be a viable option for you.
Good luck. :)
PostPosted: Thu Jul 25, 2013 3:56 pm
Image Campag shifters look and feel better for me. You have to try for yourself though. I like Campy gloss finish better. This one looks pretty cheap.
PostPosted: Thu Jul 25, 2013 4:03 pm
Hold out for Ultegra 11.
I only train on days that end with "y".
Eli
PostPosted: Thu Jul 25, 2013 4:11 pm
+1 if 6800 is anything like 9k it is worth the wait.
Sent from my iPad using Tapatalk HD
Mosaic RS-1
http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=138478
Cielo by Chris King Cross Racer
http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=134376
PostPosted: Fri Jul 26, 2013 3:41 am
Well with all the savings hitting 10 speed sram red with new 22 and force 22 out, I just ordered 10 speed sram red with the 11-28 cassette. Final cost - less than force 22 group.
There are no new unread posts for this topic. Help with Sram Red/Force RD
Hardstyle
Mon Jul 10, 2017 12:04 am
Hardstyle View the latest post
There are no new unread posts for this topic. SRAM Force 22 vs Red 22 shifters
loudtiger
10
991
Mon Aug 14, 2017 4:07 pm
youngs_modulus View the latest post
There are no new unread posts for this topic. SRAM Force left crank arm weight ?
Xico
Thu Feb 09, 2017 2:10 pm
darnellrm View the latest post
There are no new unread posts for this topic. Upgrading Campy 10-spd to 11-spd
doggled
18
1188
Fri Jun 02, 2017 10:55 pm
bikerjulio View the latest post
There are no new unread posts for this topic. Upgrading brakes on budget
eyedrop
Fri Aug 04, 2017 8:26 pm
mpulsiv View the latest post
Users browsing this forum: Bing [Bot], liam7020, Ravnsnaes, Sybarite and 33 guests
cron
