It is currently Fri Jan 19, 2018 11:00 pm
Post new topic  This topic is locked, you cannot edit posts or make further replies.  [ 7 posts ]
PostPosted: Wed Jul 24, 2013 6:22 pm
What is the current sweet spot on the price/weight curve for 27.2 seatposts?
Please use search
PostPosted: Wed Jul 24, 2013 6:45 pm
Thomson elite, good price, weight and rock solid!
Looks like I made a new 90 Proof friend
PostPosted: Wed Jul 24, 2013 6:51 pm
Since you're asking about the sweet spot, not necessarily a model brand...
I personally think that the 'sweet spot' for price & weight of a 27.2 zero-setback should be around 110g for $100. Then tune it down to sub 100g from there.
That's what I found to be the sweet spot. Easy to find? No, but it is the sweet spot if you keep your eyes peeled and have patience.
PostPosted: Wed Jul 24, 2013 7:34 pm
Thanks- any thoughts on brands? I do need set back though
PostPosted: Wed Jul 24, 2013 8:17 pm
Ritchey WCS 2 bolt carbon, mine weighed in at scant 160g for the 300mm....could probably drop to 150 with Ti bolts. Solid finish and consruction.
Here are a couple threads that have covered similar question.
viewtopic.php?f=3&t=71357&hilit=ritchey
viewtopic.php?f=3&t=108991&hilit=+ritchey
EM3
______________
PostPosted: Wed Jul 24, 2013 9:09 pm
Most seatpost I have come across are around 200 grams - am I loosing it?
PostPosted: Thu Jul 25, 2013 12:04 am
I ended up at 150g for weight sweet spot, but found that price was very variable (eventually settling at $100 + a little).
If you went for non-big-branded then you could possibly end up with something like Hylix or Bontrager knock-offs for less $.
I looked seriously at all USE versions but the ? over the clamp system put me off, and Thomson Masterpiece is not all that light against the price.
Less is more.
There are no new unread posts for this topic. Hub recommendation for new wheelset
[ Go to page: 1 2 3 4 ]
apctjb
56
2859
Tue Nov 28, 2017 12:58 am
bm0p700f View the latest post
There are no new unread posts for this topic. Quick release recommendation
woogie11
34
2222
Sat Nov 04, 2017 12:26 am
woogie11 View the latest post
There are no new unread posts for this topic. Winter tires recommendation
CallumRD1
Mon Oct 09, 2017 4:37 pm
CallumRD1 View the latest post
There are no new unread posts for this topic. Daytime Rear Light Recommendation
MRM
43
3763
Tue May 23, 2017 4:41 pm
Calnago View the latest post
There are no new unread posts for this topic. Endurance frame question, recommendation
Mtek
16
1165
Mon Dec 11, 2017 1:32 pm
idphm46 View the latest post
Users browsing this forum: Bing [Bot], carmelobymelo, cosmicman, jfranci3, KCookie and 21 guests
