CAAD10 headset options?
drainyoo
by drainyoo
Which light, durable headsets are you CAAD10 owners running? I saw the Extralite and KCNC headsets, but I'm not sure if these work since the CAAD10 has a tapered headtube with a 1-1/4" bottom bearing. Would love to get some suggestions. Thanks.
ross
by ross
I kept the Cannondale stock lower bearings and installed the upper half of a Campag Record Hiddenset
http://www.campagnolo.com/jsp/en/groups ... atid_7.jsp
drainyoo
by drainyoo
Never thought of doing that. That basically allows you to use any 1-1/8" headset. Thanks.
bluesea
by bluesea
Cane Creek sells uppers separately.
IMG_0626 by pigmode, on Flickr
bluesea
by bluesea
8mm
Rick
by Rick
Cane Creek lets you buy the upper and lower bearings/ cap separately, so you can get any of their 1-1/8th uppers with any 1-1/4 lower.
drainyoo
by drainyoo
Thanks that's a good idea, but are the Cane Creeks light?
headwind816
by headwind816
The 40 series is not the lightest, but it is meant to be economical. You can get either the short/9mm or tall/15mm cap. Both finish goes perfect with the CAAD10 black gloss finish. The price is approximately $30 including new upper bearings.
nathanong87
Resident master of GIF
by nathanong87
headwind816 wrote:The 40 series is not the lightest, but it is meant to be economical. You can get either the short/9mm or tall/15mm cap. Both finish goes perfect with the CAAD10 black gloss finish. The price is approximately $30 including new upper bearings.
i have both of them and purchased both just with the upper bearing. Good stuff from cane creek.
to the OP anything with a campy ish upper bearing will work. I had a 7mm fsa that came with my old frameset too. I think canecreek might sell a carbon version of the is42.
drainyoo
by drainyoo
It doesn't seem like there are any headsets that give considerable weight reduction. Might just be better off using the stock headset that came with my frame.
