It is currently Mon Jan 22, 2018 4:55 am
Post new topic  Reply to topic  [ 3 posts ]
PostPosted: Tue Jul 23, 2013 8:20 pm
Has anyone had experiences with Lightweight clinchers running tubeless tires? The general consensus seems to be its fine to do so, and wouldn't need any special prep work given the lack of spoke holes. But I haven't been able to find any accounts of someone actually doing this.
I currently have Lightweight Gen III tubulars but might try to trade for a set of clinchers. Overall weight would be higher but I've just had such good experiences with my other clinchers I've converted to tubeless I myself have become a bit of a convert.
PostPosted: Tue Jul 23, 2013 9:31 pm
From what I've read, and I'll admit I have zero first hand knowledge, the clincher bead on the lightweights is somewhat flimsy. They don't recommend high PSI clinchers. Now I get that tubeless tires don't require high PSI, but would they not just blow off of a flexy sidewalled rim?
PostPosted: Tue Jul 23, 2013 10:10 pm
Good point, it looks like the Gen III clinchers have a max tire pressure of 116psi. In my experience tubeless tires need a *perfect* tire bead to rim contact so flex would an issue. Although I've found a tiny amount of 3M Fast Tack adhesive around the bead (allowed to set for 24hrs) works wonders.
There are no new unread posts for this topic. Anyone running Panaracer Gravel Kings tubeless?
morganb
10
452
Tue Nov 14, 2017 3:54 am
morganb View the latest post
There are no new unread posts for this topic. anyone running 1x11 on their road bike?
adamP
21
5725
Wed Apr 19, 2017 8:07 am
mattr View the latest post
There are no new unread posts for this topic. Attachment(s) Chain length for running both 12-25 and 12-29 Campy
Alexandrumarian
Fri Aug 25, 2017 7:57 am
TobinHatesYou View the latest post
There are no new unread posts for this topic. Attachment(s) In a 2017 ww world - what is the weight penalty of running disc brakes?
alcatraz
Sat Mar 18, 2017 5:53 pm
nemeseri View the latest post
There are no new unread posts for this topic. Compatibility Question - 11 speed Crankset & 9 Speed running gear
pfnsht
13
762
Fri Aug 25, 2017 2:31 pm
goodboyr View the latest post
Users browsing this forum: BikeKingV1r, Bing [Bot], Google [Bot], MomentumR5, nemeseri, trex021, wheelbuilder, Wildh and 30 guests
