It is currently Sun Jun 25, 2017 11:38 pm
Post new topic  Reply to topic  [ 7 posts ]
 Post subject: 7800 shifter rebuilt
PostPosted: Tue Jul 23, 2013 6:14 pm
anyone take a part and rebuild a 7800 shifter?
one of mine stopped working after my bike fell over. i'd call it a crash, but i wasn't on the bike. doh.
any advice / know how out there?
 Post subject: Re: 7800 shifter rebuilt
PostPosted: Tue Jul 23, 2013 7:15 pm
What are the symptoms? If it is not clicking and the lever is just swinging, try spraying some automotive brake cleaner into it. Most of the time they are just gummed up by the Shimano factory grease. Once you get it working again, squeeze in some Prolink chain lube and you will be good to go.
R2.5 / R3 / S-Works 29er (20 lbs) / S-Works SL4 Di2 (14.7 lbs)
PostPosted: Tue Jul 23, 2013 11:08 pm
the small lever does not engage. it stick in the 'big ring' and won't down shift. the larger lever seems to work fine.
it isn't sticky... something is either broken or caught.
PostPosted: Tue Jul 23, 2013 11:17 pm
Mine was doing the exact same thing. Shimano recommends taking it off the bar and soaking it in a "gentle" degreaser over night. I left it on the bar, used a toe strap to hold it open and sprayed the shit out of it with CRC Brakeclean. After a couple sessions it worked fine. Try it, what have you go to lose? Might be a coincidence that it stuck after the fall. The factory Shimano grease turns to gorilla snot and won't let it release.
PostPosted: Wed Jul 24, 2013 12:37 am
You did make sure that the cable is not fraying inside the lever, right?
Pull the brake and shine a light through the cable access hole. If it's fraying you can often see it. You may need to shift to the large end of the cassette.
If in doubt change the cable. 7800 shifters break cables pretty quick. I get about 2500-3000 miles out of mine.
PostPosted: Wed Jul 24, 2013 7:04 pm
i don't think its a coincidence it stopped working after it fell. it was never sticky before it fell - no issues until immediately after. I'll try to spray any gummed grease from the inside, but again, i don't think thats the problem. I've had shifters with this problem before and this isn't the same.
I've removed it from the bike and removed the cable. same problem. I can see where the cable goes through - there's no frayed end or anything stuck inside.
so no one's actually taking one of these things apart?
PostPosted: Wed Jul 24, 2013 7:20 pm
sure, I've taken one apart, but it's difficult getting to the shifting internals and I wouldn't recommend it. Shimano sell the shifter assembly as part of a rebuild kit. this kit wil have the internals and levers included as one piece. swapping the parts will take you roughly 10 minutes. I believe it only requires you to remove cables and the lever pivot bolt.
I once had the link from a store selling the lever assembly but I can't seem to dig it up at the moment.
Edit:
you would need part 1a & 1b for the rebuild
  • 2011 Cannondale Flash F1
  • 2010 Cannondale Caad9
  • 2000 Caad 4 aero
There are no new unread posts for this topic. TT shifter options
Kermithimself
Mon Jul 04, 2016 8:33 am
Kermithimself View the latest post
There are no new unread posts for this topic. Worn SR shifter?
bontie
Fri Sep 30, 2016 4:26 am
tommasini View the latest post
There are no new unread posts for this topic. Campagnolo LH shifter sticky
bontie
Thu Sep 08, 2016 5:41 am
bontie View the latest post
There are no new unread posts for this topic. Campagnolo Shifter Indexing
haynesdavid1988
7
778
Mon Apr 10, 2017 3:34 am
haynesdavid1988 View the latest post
There are no new unread posts for this topic. Attachment(s) Shimano DI2 / R785 shifter woes....
BigCol
Thu Apr 20, 2017 11:06 pm
BigCol View the latest post
Users browsing this forum: Baidu [Spider], Bing [Bot], Google [Bot], JScycle, Keeno, Yahoo [Bot] and 28 guests
