Storck - Full length Internal Housing?
morrisond
by morrisond
Does anyone know if you have use full length housing on the new Storck's?
Specifically the Aernario's (Regular and Platinum)?
From Pictures it looks like you use cable ends going into the head tubes, so I'm assuming no full length housing.
I want to know if I can run Bungarus with just the inner liner running through the frame.
Thanks
jmartpr
by jmartpr
Nope...the housing ends at the stops on the frame. Maybe a thin liner could be fitted but not sure.
